Author Topic: Bedini motor  (Read 2540 times)
Offline ilanko
Bedini motor
« on: November 30, 2014, 05:18:53 pm »
Hi guys, Any one cam shade some light on what is the Bedini motor, is it a magic or a joke ?
Offline German_EE
Re: Bedini motor
« Reply #1 on: November 30, 2014, 08:44:26 pm »
It's not magic or a hoax, it's a scam. These people need beating over the head with the laws of thermodynamics (more than once).
Warren Buffett
Online hexreader
Re: Bedini motor
« Reply #2 on: December 01, 2014, 12:45:57 am »
A Bedini motor is an incredibly efficient motor which works using the principle of smoke and mirrors.
It is a dual- fuel motor, which makes it cheap and easy to run.
Most people run it on snake oil, which is in plentiful supply, but very expensive.
Luckily the other fuel it runs on is bull-s**t, which is extremely cheap and can be found almost anywhere you look  ;D
« Last Edit: December 01, 2014, 12:52:18 am by hexreader »
Offline Andy Watson
Re: Bedini motor
« Reply #3 on: December 01, 2014, 12:50:35 am »
but, better than cheap, a lifetime's supply is included in each installation.
Offline ilanko
Re: Bedini motor
« Reply #4 on: December 27, 2014, 04:00:23 pm »
Thank you for the  :-DD replay. Love the  smoke and mirrors Happy 2015
Offline SL4P
  • There's more value if you figure it out yourself!
Re: Bedini motor
« Reply #5 on: December 28, 2014, 12:50:27 am »
You're doing it wrong...
I think they're using the wrong type of bearing.
It should be a 'thrust bearing'
All the School Girls that I've ever turned on - had a definite squeal or rhythmic squeak on each cycle of the mechanism.
Don't ask a question if you aren't willing to listen to the answer.
Offline calexanian
    • Alex-Tronix
Re: Bedini motor
« Reply #6 on: December 28, 2014, 02:47:43 am »
This car gets infinite fuel mileage! So long as wherever you are going is downhill the whole way, and not below a grade that equates to the static friction of the car. Otherwise you are golden!  I also have a bridge in Brooklyn for sale if you like. (Yank Joke)
Charles Alexanian
Alex-Tronix Control Systems
