Author Topic: Looking for a project box to match this one  (Read 607 times)
Offline cowasaki
« on: March 01, 2020, 07:08:46 pm »
I have a couple of project cases which I have built valve testing equipment into. There are a couple of further pieces I want to build and it would be nice to have them match. Does anyone recognise this case and have any idea where I can get one. It’s about 230mm wide I’d guess. Will post dimensions later.
Offline WattsThat
Re: Looking for a project box to match this one
« Reply #1 on: March 01, 2020, 07:24:25 pm »
Kinda sorta like what is pictured:
https://www.aliexpress.com/item/32901775288.html
« Last Edit: March 01, 2020, 07:26:04 pm by WattsThat »
Offline aargee
« Reply #2 on: March 02, 2020, 12:05:57 am »
Meanwhile in Australia...
Altronics and Jaycar sell very similar boxes, not sure where in the UK you might buy them e.g.
https://www.altronics.com.au/p/h0482-260x190x80mm-abs-grey-black-instrument-case/
or
https://www.altronics.com.au/p/h0480f-200x155x65mm-abs-grey-black-instrument-case/
Look pretty close.
Not easy, not hard, just need to be incentivised.
Offline cowasaki
« Reply #3 on: March 02, 2020, 01:36:39 am »
Thanks. The Aussie one looks closer but I can’t see the top. I’d really like the exact box as I’m making a set of devices that will work together. I saw it on eBay a few months ago but you get thousands of boxes and it’s hard to narrow it down. I can’t remember the seller or if there was a brand.
Offline jesuscf
« Reply #4 on: March 02, 2020, 04:19:35 am »
The box looks a lot like the series 1598 from Hammond Manufacturing.  DigiKey carries some.  Sadly I can not find one with the same venting holes.
Homer: Yeah, but faster!
Offline jesuscf
« Last Edit: March 02, 2020, 05:03:22 am by jesuscf »
Offline ebastler
« Reply #6 on: March 02, 2020, 06:39:42 am »
As a side note, the "ventilation" slits on that enclosure look like they are just symbolic in nature. They will prevent the build-up of excessive pressure inside the case, but not do much more, I guess. ;)  But I take it that your valves, and other heat sources if applicable, will all be mounted on the outside?
Offline cowasaki
« Reply #7 on: March 02, 2020, 10:19:12 am »
That is the same box! Amazon will not send it to the U.K. and the American seller would cost me $50 plus when it came in they would charge me vat making it $60 and a £18 handling charge :-(
Still need to find it in Europe but many thanks for spotting those.
Offline Johnny10
« Reply #8 on: March 02, 2020, 02:41:17 pm »
Do you have your uTracer 3 in that box?
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
Offline cowasaki
« Reply #9 on: March 02, 2020, 03:06:34 pm »
I have a duokit2 with some extras in one and two transformers, a 20v and 12v wired forward and reverse giving me 300+ volts AC with the other 20v giving DC and filament heater voltages. I want one for an output stages and one for a tracer. I might need different output stages in their own. I just think it would look neater with all my valve stuff in matching boxes.
Offline cowasaki
« Reply #10 on: March 02, 2020, 03:11:46 pm »
I’m developing a valve amp brick system. An input brick, bricks for 9 and 8 pin valves, a brick for tone stack, bricks with replaceable pots, a brick with breadboard, a reverb brick etc
The idea is that you could hook together any idea for a valve amp in ten minutes and swap components in and out.
These are finished 9 pin bricks and a tone stack brick (the pots are also switchable with different values and there is a bypass. The banana plugs are in, out and ground)
Offline cowasaki
« Reply #11 on: March 02, 2020, 03:15:06 pm »
All the bricks are the same size. The first is an octal brick but I’ve run out of the right octal valve sockets. That valve is just sat in the hole
Offline Johnny10
« Reply #12 on: March 02, 2020, 03:16:38 pm »
So like a plug and play guitar amp?
Online nali
« Reply #13 on: March 02, 2020, 04:21:13 pm »
As it happens I have a near identical case sitting on a shelf gathering dust. It's slightly different to yours (vent holes) and a bit larger @ 300x200x75mm but you're welcome to it for postage.
The following users thanked this post: cowasaki
Offline jesuscf
« Reply #14 on: March 02, 2020, 04:40:34 pm »
I feel your pain!  Found another source in USA:
https://www.alltronics.com//cgi-bin/item/IC115B/10/10%22-(W)-x-7.4%22-(D)-x-3%22-(H)-Heavy-Duty-Desktop-Project-Box-
Even if the shipping cost is high, they list the box for 12.95$.
Offline rdl
« Reply #15 on: March 02, 2020, 06:08:39 pm »
I have one of those also. It's a dead ringer for the one in that ebay listing above. Pretty sure I  bought it from Jameco many years ago for a never finished project. Only $8.95
https://www.jameco.com/z/WCA-H2507-ABS-Heavy-Duty-Instrument-Case-10x7-5x3-1-_18877.html
They have a data sheet from the manufacturer which might be helpful in tracking down a local source.
https://www.jameco.com/Jameco/Products/ProdDS/18877.pdf
Offline jesuscf
« Reply #16 on: March 02, 2020, 06:16:58 pm »
Excellent!  Now we have a part number: WCA-H2507.  Now it is easy to find a supplier in the UK:
https://quasarelectronics.co.uk/Item/wcah2507-abs-heavy-duty-instrument-case-250x190x80
Offline cowasaki
« Reply #17 on: March 02, 2020, 07:13:38 pm »
That would be very useful thanks, I will PM you.
Offline cowasaki
« Reply #18 on: March 02, 2020, 07:15:00 pm »
Brilliant.  Thanks!  I knew that someone on here would be able to locate them :-)
Offline cowasaki
« Reply #19 on: March 02, 2020, 07:16:39 pm »
Thanks for your help.  That data sheet is useful too.
Offline cowasaki
« Reply #20 on: March 02, 2020, 07:25:12 pm »
Absolutely that!
I have finished building 2x 9 pin valve sockets (usually preamp valves) and a "Tone stack" which usually sits after the first couple of stages of preamp and before another couple then the power amp.
So with the power amp box, these two 9 pin bricks, the input stage I am building tonight and the tone stack brick we have a working guitar valve preamplifier.
I have the octal bricks ready but no sockets (which are on order) that will create the power amplifier section with an output transformer and speaker.
I will be launching all of the bricks plus others like a distortion brick, reverb brick and tremolo brick on thingiverse when they are complete.  Either than or I'll become a millionaire and sell them fully built.
The tone stack box is the one with 3 pots, 3 banana sockets, a switch and 8 holes with .254" headers inside them.  THIS setup is a standard FENDER tone stack. By changing the 3 caps and resistor then turning the box over and swapping out the pots for different values you can get a Marshall or Vox tone stack.  You can also mess around and have something in between.  The Tone stack box can be used stand alone to add a tone stack to an amp without one and then you can hard wire it once you have a sound you like.
« Last Edit: March 02, 2020, 07:28:18 pm by cowasaki »
