Author Topic: QUIZ for strong players: The Winner gets 0,1EUR  (Read 2968 times)
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« on: December 10, 2011, 04:16:41 am »
The one who will be able to do the sum of the counts of this meters will Win 0,1EUR .
This is my digital Christmas card for the EEV friends.
Have fun with it, or ignore it.
Offline tnt
Re: QUIZ for strong players: The Winner gets 0,1EUR
« Reply #1 on: December 10, 2011, 09:19:37 am »
302.732 ?
Unfortunately, due to the parallax, the analog meter is nearly impossible to read correctly ... (I read it at 6.9)
Offline WattSekunde
« Reply #2 on: December 10, 2011, 10:18:55 am »
252.132 without the 50.5 from the function generator display because it's not really a meter? :o ???
I guess 6.8 on the analog "display". I think the shadow is a little to much right because of the bright light from the left (6.85). See also the shadow from the black or red cable below. And the indicator is a little to much left due the point of view (6.75).
That was funny. And next year you start the 24 doors "Adventskalender"... ;D
Michael
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
« Reply #3 on: December 10, 2011, 03:37:48 pm »
This is why I added the analogue meter so to confuse you !!  ;D
Offline Mint.
  • Account is inactive now. Thanks everybody!
    • Personal Blog, Mint Electronics.
« Reply #4 on: December 10, 2011, 10:42:40 pm »
Very smart *thumbs up*. Too hard for me so I'm gonna pass ::).
Personal Blog (Not Active Anymore), Mint Electronics:
http://mintelectronics.wordpress.com/
Offline tnt
« Reply #5 on: December 11, 2011, 12:13:06 am »
Actually depending on what he meant, the actual value could be irrelevant. Like if he meant the "count" as in "a 2000 count meter".
Too tired to compute an actual value for that tough.
Offline snoopen
« Reply #6 on: December 12, 2011, 05:14:46 am »
Assuming the analogue is reading 6.8v then:
Sum volts: 69.078
Sum volts + hz: 169.638
Sum volts + hz + temp: 182.938
Offline Psi
« Reply #7 on: December 12, 2011, 06:43:52 am »
The sum is X = A + B + C + D + E + F + G + H + I + J + K + L + M
Where A-M equals the value on each display.
You should have asked for the solution   ;D   :P
:Joke:
« Last Edit: December 12, 2011, 06:46:03 am by Psi »
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
« Reply #8 on: December 12, 2011, 06:44:08 pm »
I like to confirm that I am impressed from the level of humor of our Australian members, looks that the grumpy Vernon is a major exclusion.
Offline xiaoshanj
« Reply #9 on: December 12, 2011, 09:35:40 pm »
68.872
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
« Reply #10 on: December 12, 2011, 09:57:35 pm »
The counts of the function generator is excluded.  ;D
Welcome in the forum.
Offline ivan747
« Reply #11 on: December 13, 2011, 01:31:13 am »
They are SO sarcastic.
By the way, is the prize really €0.1? I was expecting a reviewed multimeter *hint* *hint*  :D
« Last Edit: December 13, 2011, 01:33:15 am by ivan747 »
