Author Topic: Would you drive under this plyon?  (Read 3055 times)
Offline AvaceeTopic starter
« on: April 19, 2017, 04:14:46 pm »
http://www.bbc.co.uk/news/world-asia-39645534
Go on, dare you! - your vehicle is a Faraday Cage :)
What goes poof just after it starts to fall? .. Is that part of the design in case of a failure?
Offline Tom45
Re: Would you drive under this plyon?
« Reply #1 on: April 19, 2017, 05:15:12 pm »
What the brave soul (idiot?) that was spraying water on the fire?
Offline bsudbrink
« Reply #2 on: April 19, 2017, 06:26:50 pm »
Sort of like a scene from an old Godzilla movie.
Offline Red Squirrel
« Reply #3 on: April 20, 2017, 04:41:58 am »
We must construct additional pylons!
The following users thanked this post: IdahoMan
Online Vgkid
« Reply #4 on: April 20, 2017, 06:05:28 am »
I'm surprised this comment didn't happen sooner.  ;D
Offline R005T3r
« Reply #5 on: April 20, 2017, 09:24:29 am »
Never heard about crane-truck contact?
Offline jm_araujo
  • Country: pt
« Reply #6 on: April 20, 2017, 10:53:47 am »
I'm waiting for the conspiracy theorists to say that it must have been an inside job, open air flames (like fuel) can't melt steel beams   |O
The following users thanked this post: boffin, tooki
Offline jeroen79
« Reply #7 on: April 20, 2017, 11:18:49 am »
Offline TerraHertz
    • It's not really a Blog
« Reply #8 on: April 20, 2017, 01:24:54 pm »
The transmission line circuit breakers trip just as it's starting to tilt, with those arc-overs as the cables get too close to the pylon. So after that point it's all mechanical. Thin sheet metal Faraday cages are moot, when it comes to tons of falling steel girders.
That said, after it gets hung up by cable tension, I would drive under it - for enough money.
As for building (slum) fire 'melting' steel - no, but it can get thin steel girders hot enough to go soft. And those pylon girders are thin.  The important point being that their thinness prevents much heat loss by conduction from the section within flames, along the girder to cooler areas. Also the absence of fire insulation on the pylon girders, unlike the very good fire protection all steel frame skyscrapers have around the pillars
For what fire does to thin, unprotected, low thermal mass steel girders, I'm sure everyone has seen the twisted tangles of collapsed steel roof girders after fires in small factories.
Otoh, building fires cannot heat steel up enough to form rivers of bright yellow molten steel flowing out the window openings of a skyscraper. And yet there are multiple clear videos of this happening in a specific case.
Offline zl2wrw
« Reply #9 on: April 21, 2017, 06:39:14 am »
[SNIP]
If you are talking about the skyscrapers that I think you are, "ordinary" building fires do not involve the high speed injection of tens of tons of aluminium (plus the chemical oxygen generators and portable oxygen cylinders which are typically carried with said mass of aluminium).
I understand that the oxidation of aluminium is so exothermic that it can rip oxygen atoms off of iron oxide, resulting in bright yellow molten iron (thermite reaction). Aluminium is also capable of stealing oxygen atoms from H2O, resulting in aluminium oxide, hydrogen gas and a whole lot of heat! (ask the British navy about the Falklands war...) - a broken water pipe (toilets on each floor in those skyscrapers?) and or fire sprinklers would be a source of oxidiser for an established aluminium fire :wtf:
Yes, it is hard to ignite aluminium, but a bit of oxygen enrichment (see above) will fix that...
Offline German_EE
« Reply #10 on: April 21, 2017, 02:54:36 pm »
No way would I drive under that pylon if I knew that there was a fire at its base, I would park 100m away and watch what happens though. The big surprise is that the authorities didn't stop the traffic once the fire had started!
Warren Buffett
Offline chris_leyson
  • Country: wales
« Reply #11 on: April 21, 2017, 05:03:02 pm »
Hot rolled steel starts to loose its strength at around 300C and at 500C it's down to half strength so I'm not surprised the legs failed. Static load on the structure is maybe around 40 to 50 tonnes.
