Author Topic: Wrist Heater/Cooler???  (Read 2383 times)
Offline SgtRock
« on: November 02, 2013, 06:30:03 am »
Greetings EEVBees:
--Please see below for a link to a very puzzling article about a device called "Wristify" which can apparently help a person acclimate to a hot or cold building. No doubt the device, having been designed at MIT, probably actually does something, but just what is impossible to tell from the article. It is not at all clear to me whether the device warm or cools one, or merely one perceptions, go figure. The article also mentions "hot and cold waveforms", go figure some more. If anyone can make heads or tails of this one, please comment.
http://www.independent.co.uk/life-style/gadgets-and-tech/news/forget-your-jumper-this-thermoelectric-wristband-can-heat-or-cool-your-entire-body-8918320.html?origin=internalSearch
"Horse sense is the thing a horse has which keeps it from betting on people."
William Claude Dukenfield, W. C. Fields 1880 - 1946
Best Regards
Clear Ether
Offline AmmoJammo
Re: Wrist Heater/Cooler???
« Reply #1 on: November 02, 2013, 06:31:54 am »
looks like a peltier tied to your wrist.... didn't bother reading the article  :-DD
Offline amyk
« Reply #2 on: November 02, 2013, 11:15:59 am »
heating or cooling parts of the skin can help influence how hot or cold we feel over our entire body
Great way to get hypothermia/hyperthermia while feeling perfectly fine...
Offline G7PSK
  • It is hot until proved not.
« Reply #3 on: November 02, 2013, 01:36:39 pm »
I got the idea from reading the article that the idea was to strap a heat sink on your wrist to cool you instead of turning on the AC. A bottle of water poured over you would be more effective and better to look at on the female population. :-DD
Offline Rufus
« Reply #4 on: November 02, 2013, 03:13:30 pm »
It is a peltier and heatsink stuck on your wrist with wires going to a no doubt stupidly impractical power supply.
Blood flow distributes heat around the body but to have a worthwhile effect a patch on your wrist would have to be uncomfortably hot or cold. The idea that it can make you think you are warm or cold is bollocks IMO.
Trying to control the temperature of your body instead of the environment the body is in has merit because it requires much less energy. Stored energy in hot/cold water which is replenished every hour or two is much cheaper and practical, especially compared to inefficient peltier devices.
