Author Topic: WTF is he thinking?!  (Read 12037 times)
Offline smashedProtonTopic starter
« on: September 11, 2013, 12:41:33 am »
http://www.garrettbaldwin.com/
Invention, my dear friends, is 93% perspiration, 6% electricity, 4% evaporation, and 2% butterscotch ripple.
Offline c4757p
  • adieu
Re: WTF is he thinking?!
« Reply #1 on: September 11, 2013, 12:44:40 am »
"Man, this weed is good."
Offline marshallh
    • retroactive
« Reply #2 on: September 11, 2013, 01:12:08 am »
Saw that earlier today.
The implementation is pretty much physically impossible. You can't drive high freq nets into a 10x10 pcb i/o crossbar and expect it to work, even if you had a 100 layer pcb to play around with.
Now the only potential I see here is for a generic skeleton pcb with fixed locations for the hardware. I.e. radio goes in upper left, period, not movable or sizable.
Same for CPU and memory. Put them on a block with a ultra fine spring tip connector on the backplane pcb.
All this overhead adds to the cost, so it'll be much more expensive than a commodity phone, bulkier, heavier, and less power efficient. But at least you'd be able to swap out the CPU with a faster one so you can run all those crap javascript abstractions.
I can see it now, upgrade board every 6 months to keep your 10 second hangup time from getting even worse with updates...
Verilog tips
BGA soldering intro
Offline c4757p
  • adieu
« Reply #3 on: September 11, 2013, 01:14:21 am »
All those connectors will make it so unreliable you won't be able to upgrade it by the time new parts come out. The USB port on these damn things is bad enough, imagine if the cost-cutters had to juggle a dozen high-speed interconnects...
Offline Psi
« Reply #4 on: September 11, 2013, 01:36:06 am »
As a pure idea I really like it. It would be great if you could easily replace or later upgrade a battery or screen or even increase the memory or most appealingly the processor core rather than contributing to e-waste.
Same.
I class this in the category of 'good ideas that are so good that they will probably never happen'.
That said, as electronics get smaller and smaller and it becomes less easy for product manufactures to interact with them directly (beyond BGA etc) it does start to make sense to have things modularised straight from the manufacture.
At that point something like this may become feasible if manufactures standardise on the module specs.
« Reply #5 on: September 11, 2013, 01:48:52 am »
I think that the concept of upgrading the hardware on the phone is pretty dumb.  You would only ever want to change out the cpu and the memory at the same time otherwise you would have a major bottleneck.  Also, you would want to change out the battery with the cpu and memory to account for the different power requirements of the new hardware.  A much better idea is to have a properly designed cell phone that you replace as a whole when technology has evolved.
Offline c4757p
  • adieu
« Reply #6 on: September 11, 2013, 01:53:03 am »
I think the average phone owner is about as likely to upgrade hardware as the average PC owner - not very likely. Aunt Sally doesn't add RAM, she buys a new computer when hers gets slow - even though it's only slow because it's caked with her crap! :-DD The same would be true of a phone.
Offline pickle9000
« Reply #7 on: September 11, 2013, 02:57:26 am »
A more likely scenario is a single chip with everything on it that plugs into the case of your choice. Kinda sucks if your not a chip designer though.
Offline staxquad
  • Eye Candy
« Reply #8 on: September 11, 2013, 04:53:27 am »
the screen resolution is being upgraded all the time, which is the base, so their concept is obsolete already, they are try9ing to keep one component static while improving the rest, not real world
"TEPCO Fukushima you long time"
You say Vegemite, I say Yosemite. (Ve-gem-mit-tee, Yo-zey-might)
"For starters : you're Canadian...."
Offline BravoV
  • +++ ATH1
« Reply #9 on: September 11, 2013, 05:12:52 am »
Isn't the current "proven" business model and also the most important factor which is the consumers them self are willing dying to have a new look/feature/get bored every year that made this concept looks pale, even technically its possible.
Asking the current consumerism addicted mob to stick with the same model, look and feel even with upgraded feature "internally" for long period is suicide from the current cell phone business perspective, cmiiw.  :-//
« Last Edit: September 11, 2013, 05:31:12 am by BravoV »
Offline rexxar
    • Forever Tinkering
« Reply #10 on: September 11, 2013, 05:13:02 am »
The screen was also upgradable.
Offline AlfBaz
« Reply #11 on: September 11, 2013, 05:15:26 am »
Bugger phones, this seems like a good idea for lego to move into the 21st century :)
Offline MatCat
« Reply #12 on: September 11, 2013, 05:16:25 am »
Interesting that the official webpage goes to a blankly setup apache page, rofl.
Offline PA4TIM
« Reply #13 on: September 11, 2013, 06:07:56 am »
Custommer: Great, I want the bigger camara, bigger memory, bigger battery and bigger speaker, please.
Salesguy: that is not possible
Custommer: What do you mean with "that is not possible ? " Oh, the case is to small, so if I choose a better camara it will cost me battery space, memory and storagespace ? That sucks.....
The first breadboard phone
Offline Psi
« Reply #14 on: September 11, 2013, 06:48:07 am »
That's life, and applies to everything.
Offline Corporate666
  • Remember, you are unique, just like everybody else
« Reply #15 on: September 11, 2013, 07:01:46 am »
This guy is well intentioned, but incredibly naive about business, about electronics, about marketing, about sales, about R&D, about inventory, about retail, about distribution, about IP, about technology and about pretty much every single important point one needs to be a successful entrepreneur.
It's like saying "I have a great idea.  It's for a flying car that packs into a suitcase as you jump out of it.  It runs on anti-gravity so it can never fall from the sky, and it will never break down.  All we need is a hundred million people to agree to the idea, and we'll go to Apple and they will make it for us".
It's not always the most popular person who gets the job done.
Offline PA4TIM
« Reply #16 on: September 11, 2013, 07:22:29 am »
it's like saying "I have a great idea.  It's for a flying car that packs into a suitcase as you jump out of it.  It runs on anti-gravity so it can never fall from the sky, and it will never break down.  All we need is a hundred million people to agree to the idea, and we'll go to Apple and they will make it for us".
Sounds like a good idea, and if Apple won't make that i-car, we go tho Microsoft and they build it with a W8, onlt downside will be the ctrl-alt-del keys to shut down the engine.
Or better, lets make an open source version of that car, and call it a linuxine
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #17 on: September 11, 2013, 08:30:17 am »
Nice idea in principle but they are clearly totally clueless about electronics and marketing - companies don't want to work together to make the best phone, they want to make the biggest profit.
hopelessly impractical.
Day Job: Mostly LEDs
Offline amyk
« Reply #18 on: September 11, 2013, 10:39:32 am »
To a certain extent, phone upgrades/repairs occur a lot more in China. There is of course no standard form factor but due to cost/labour reduction (and desire to cloning) a lot of the manufacturers have converged to the same designs using the same components.
Offline Sionyn
« Reply #19 on: September 12, 2013, 09:29:53 am »
this will never work
eecs guy
Online dexters_lab
« Reply #20 on: September 12, 2013, 06:26:12 pm »
yea saw this posted on my FB, my first thoughts were yea i would like to see that work in the real world  :palm:
it just hasn't been thought through
far better to just put the effort into making things more recyclable
Offline youbecha
Is the Phonebloks concept phone even possible?
« Reply #21 on: September 12, 2013, 11:37:11 pm »
I am not going to advertise for it, but search for phonebloks or just open up the internet and you will see some push for it.  (at least all over the tech media)...there is a feel good video attached to the story.
The concept is an entirely modular cellphone.  every component is in its own box, with magic pins to connect all the boxes to each other and to a display...and every portion of the phone can be re-arranged added or subtracted...like legos.  (or 80's era bread board components for teaching electronics in college)
The purpose is to reduce electronic waste by only changing components that are broke, and only buying components that you need.
I personally think as a minimum the entire phone would double in size (so still tons of waste) just to account for all the additional packaging...not to mention signal length issues, and RF issues...and how the heck to wire it...
What say you?
Offline Legit-Design
Re: Is the Phonebloks concept phone even possible?
« Reply #23 on: September 12, 2013, 11:43:03 pm »
Possible, yes (though not the way they picture it), but  it would be too big, heavy and expensive for anybody to want it.
Offline MacAttak
« Reply #24 on: September 12, 2013, 11:54:23 pm »
"Possible" is a big word. Very few things in this universe are NOT possible, given enough time.
