My Dad was a Stenotype ("machine shorthand") reporter for many years. I never learned it myself, but the machine printed regular upper-case characters in 22 columns across the paper strip, with each column dedicated to a specific character (e.g. column 1 was S, column 2 was T) and the reporter pressed multiple keys simultaneously to print multiple characters on a line. His career was entirely with the original machines which printed on paper, now obsolete and replaced by computer-based equipment. At the end of the day, he's give his notes to a "notereader" who typed them up as a plain-text transcript. There were enough variations in shorthand style among reporters that the notereaders worked with the same reporters as much as possible.
Thanks for that,
Albert!. I know this is not the same, but you reminded me of when I was an Electrician in about 1975/1978 ? for the
"Advertiser" Newspaper in Adelaide Australia. All the 'Type-Setting' was done on '
Linotype' machines. It had a Type-Writer style keyboard,
and as they typed each column line, it would actually
MOLD a Lead stackable strip from molten Lead, to drop down into a collection tray!!...
In These strips, the writing was back to front, because when the whole 'Page' block was made up, it was pressed with a hundred ton press
into an 1/8th or 3/16th (?) thick sheet of 'Elephant-Hide'. (Actually a VERY hard type of cardboard like material). Here are some molded lines...
The final 'cardboard' page sheet was bent into a half-circle, and placed in another machine that molded another approx 3/8th or 1/2 inch thick
molding, becoming half a cylinder. (Actually from a mix of Lead, Tin & Antimony, for strength and low temperature expansion/shrinkage).
Two of these, were then placed together in the actual printing machine, to make
each circular drum!!
Interestingly... The black ink then was kerosene based, and so NEVER really dries, by the time the paper is on your kitchen table! They say
it is technically as wet then, as it was at the moment of printing!! (So watch out for those 'Fish-n-Chips' and other foods!! )
Also interestingly... I remember an old guy there, who started there when he was only 15-yo or something, and actually worked for 50 years
there, which is impossible these days. And he NEVER had ONE day off !!! He was a GREASER, and his job was going over the literally thousands
of grease-nipples on the huge line of printing machines that took up space from the basement to the 1st floor for each machine in line!
Even after he 'retired', he was back there at 5 or 6 am every day, as he literally had nothing else to do in his life!!
We take so much for granted these days, where everything is digital & computerized....
