Urrgh.... thanks for making me think of.... those things.
Hard to pick the worst one. Maybe this:
I'd always wanted a Tektronix 7104 1GHz analog scope. Pinnacle of the beautiful engineering Mt Everest that the Tek 7000 scopes were. All my working life I'd coveted them, but never could afford any. Then discovered ebay around 2000, and finally around 2006 bought a 7104 from the USA. It arrived undamaged, and working fine. I had also bought a service manual.
As advertised, the scope was quite dirty and had slight surface corrosion in a few places. Nothing unrepairable. So I set about restoring it.
Now as we ALL know, the very first thing you do when disassembling anything containing a CRT, is to discharge the CRT anode to a suitable ground, typically the CRT outside grounding braids or case.
In the 7104, the CRT anode lead has an in-line HV plug, which is easier to get to than the clip on the side of the CRT.
But to reach the plug, you have to reach into a narrow space between the deflection amp board and the CRT.
I reached in, both hands, and gripped the two plug halves. Pulled them apart.
Then accidentally dropped the male end one (from the CRT.) It fell down past the amp board, and made that 'SNAP!' sound of a HV discharge. To the 1GHz amplifier board, covered with irreplaceable weird Tek custom ICs.
Needless to say, the 7104 is completely dead. Power supply doesn't start for one thing, and that too contains custom Tek ICs. Half-hearted depressed attempt to get the power supply going with dummy loads failed. After that the whole thing got put away as too horrible.
Sob.
