Incorrect use of “percent increase”. Should be later value minus earlier value divided by earlier value times 100, i.e. change related to starting value. So, if value was 100 and increased to 200, percent increase is (200-100)/100*100 = 100. But can find it as (200-100)/200*100 = 50 percent increase. Or as 200/100*100 = 200 percent increase (this one is commonly used for investment sales). Or even (200-100)/[(100+200)/2]*100 = 67 percent increase.
Mike
So, what is your take on marketing claiming a % increase/decrease in temperature?
Gamer's Nexus went absolutely nuts at some manufacturers for saying things like a case had 15% better cooling and 5% lower temperatures.
He was like, YOU CANNOT APPLY PERCENTAGE TO A DEGREE!!!! and basically detonated.
Oh, you can correctly calculate a % increase or decrease in temperature. Question is whether it has any meaning. Suppose an object is 50C. A 50% decrease in temperature brings it to 25C. That 50C object is 122F. A 50% decrease from 122F is 61F. But 25C is 77F, not 61F! A percentage increase or decrease in an intensive variable with an arbitrary zero isn’t all that quantitatively useful by itself. There can be directional and ordinal comparisons. A decrease is colder; increase is warmer. Comparing two identical objects that are cooling from the same starting temperature, the one with the biggest % decrease in temperature got colder.
Calcs get a little messy if a % change takes the temperature through zero. If an object is 16C and has a 50% decrease in temperature, that’s 16 x 0.5 = 8. What about a 150% decrease? 100% decrease would take it to zero. A further 50% decrease takes it to 16 x -0.5 = -8.
However, % decrease/increase in temperature can be used in calculations with other quantities to obtain useful results. If the mass of an object, it’s specific heat, it’s starting temperature and % decrease/increase in temperature are known, then a potentially useful % change in its thermal energy content can be calculated.
Percentage changes in cooling can have useful meaning depending on how it’s calculated. If 100 J per second was being removed from a source and now it’s 150 J per second, that’s a 50% increase in cooling, i.e. 50% better cooling.
Mike
