Author Topic: Youtube problem  (Read 7045 times)
Offline Rick
  • Country: tr
Youtube problem
« on: August 02, 2012, 03:15:03 pm »
I have recently reinstalled my Windows XP because of what I thought was a virus infection.
However, since then I cannot view continuously Youtube videos, they stop after a few seconds then I need to click again to continue viewing. I found on internet, the reason may be an ad blocker but there is no such setting I believe.
What can be the cause of this?
Offline Relaxed
Re: Youtube problem
« Reply #1 on: August 03, 2012, 01:08:21 pm »
I had pretty much the same problem before. Strangely it happened out of nowhere...I used to use firefox with adblock when i was suddently getting similar problems.
I then switched to google chrome (also in combination with adblock) and i wasn't having any issues anymore.
Hope this helps
Relaxed
PS: You might wanna use the "Bookmarked tabs to the front" addon for the same bookmark-behavior as firefox.
Offline johnboxall
  • Problems are solved by taking action.
Re: Youtube problem
« Reply #2 on: August 03, 2012, 01:31:54 pm »
Try changing your HTML5 settings
https://www.youtube.com/html5/
Offline Psi
Re: Youtube problem
« Reply #3 on: August 03, 2012, 04:26:19 pm »
If you have a cheap wireless mouse or keyboard check the batteries. Sometimes when they get flat they start doing random things, like clicking (which would stop your video)
Also, if you reinstalled windows make sure you install all the needed drivers.
chipset / directx / video / flash / etc.
Online TerminalJack505
Re: Youtube problem
« Reply #4 on: August 03, 2012, 05:11:36 pm »
There was another thread about this not too long ago.  It seems to be a common problem.  I had the problem myself for the longest time.  It seems to have gone away in the last couple of days, though.
I think the problem is/was with YouTube's streaming algorithm.  They seem to have changed it recently and they no longer stream the entire video all at once.
The workaround for the problem is/was to stop the video and switch to a different quality then back to the original quality.  This seems to allow the old behavior where the entire video would be allowed to be streamed.
It's interesting that switching to Chrome fixes the problem considering who makes Chrome and who owns YouTube.
Offline tom66
  • Electron Fiddler, FPGA Hacker, Embedded Systems EE
Re: Youtube problem
« Reply #5 on: August 03, 2012, 10:37:19 pm »
YouTube is a nightmare.
Neurotically unable to stick to one design; every second month it's different!
Excessive copyright controls. (Why do copyrighted and de-listed videos still show in search?)
Excessive ads. Actually Adblock Plus eliminates that. :)
But there are no other options.
Offline recharged
  • Country: aq
  • Here to learn
Re: Youtube problem
« Reply #6 on: August 03, 2012, 11:16:43 pm »
The best way to tackle some of these random problems is to either disabled any addons you are not using or if on Firefox you might want to check up on updates or moving down from any recent update. I had a strange video related issue which was somewhat like what you are experiencing and it turned out to be my video driver.
Offline G7PSK
  • It is hot until proved not.
Re: Youtube problem
« Reply #7 on: August 04, 2012, 08:15:26 am »
I have a very slow internet speed, due to the distance from the exchange so I have to download all video for which I use real player. Now suddenly 2 days ago I find that I cannot down load any video at all and that includes Dave's. I have removed and re-installed Real player and tried a couple of other downloaders nothing works. I am really peed of at the moment.
Re: Youtube problem
« Reply #8 on: August 04, 2012, 01:50:36 pm »
Yuck Real Player......... Toss it out and use VLC. To download use Flashgot with Firefox, works well.
Offline G7PSK
Re: Youtube problem
« Reply #9 on: August 04, 2012, 02:22:30 pm »
I use VLC for play back but have not found anything as good as realplayer for the download. It has the automatic do you want to down load this or it used to. I also use Chrome as browser will flagshot work with that I will give it a go.
Offline Rick
  • Country: tr
Re: Youtube problem
« Reply #10 on: August 04, 2012, 04:43:32 pm »
The same problem occurs with Google Chrome and Internet explorer too.
I am using firefox and Opera mostly.
Strangely my second computer shows the same problem although they are not interconnected but both of them run on Windows XP.
Whereas my laptop which has a W7 operating system does not have that problem and I can watch youtube videos normally on my laptop.
I tried to reinstall XP 3 or 4 times but that did not solve my problem.
I do not have a wireless mouse on this computer.
"The workaround for the problem is/was to stop the video and switch to a different quality then back to the original quality."
I also tried that and it does not work for me unfortunately.
That does not seem to be a youtube specific problem.
I got an error message on the eevblog web page. It seemed to complain about a java or javascript related problem. But I do not get that message any more.
The same problem occurs with dailymotion videos too.
This is a problem with streaming videos only.
All videos stop at around 11 sec.
Finally I switched to html5 and now I cannot not play videos at all.
« Last Edit: August 04, 2012, 04:55:00 pm by Rick »
Offline T4P
  • Country: sg
    • T4P
Re: Youtube problem
« Reply #11 on: August 04, 2012, 05:15:21 pm »
What's your flash version?
Oh and please check your chrome version too
Plus update your java if possible
Offline Rick
  • Country: tr
Re: Youtube problem
« Reply #12 on: August 04, 2012, 05:16:57 pm »
11.3.300.270
I have downloaded and installed a new version of Java but the problem persists, anyway I shall have to watch youtube videos on my laptop for a while.
« Last Edit: August 04, 2012, 05:22:59 pm by Rick »
Offline G7PSK
Re: Youtube problem
« Reply #13 on: August 04, 2012, 09:20:42 pm »
Chrome seems to have broken a lot of thing recently. My mother in law complained that she could not print of her emails today, I had a look her printer is fine and works with every thing other than chrome, only way to get it to print in chrome is Ctrl.+Shift+P command. Ctrl. P does not work and neither will the print button, So I had a look at my computer and using either Ctrl.P or the print button prints one extra totally blank page  now, so the latest update is obviously buggy.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
Re: Youtube problem
« Reply #14 on: August 05, 2012, 02:23:22 pm »
what windows XP? SP3? i use winXP SP3 without any problem with youtube.
if something can select, how cant it be intelligent? if something is intelligent, how cant it exist?
Online Simon
  • Global Moderator
    • Simon's Electronics
Re: Youtube problem
« Reply #15 on: August 05, 2012, 04:27:46 pm »
No! it's interesting that even on chrome the damn thing does not work !!!! I suspect it could also be issues with ISP's as morre and more use is made of youtube.
https://www.simonselectronics.co.uk/shop
Varied stock of test instruments and components including EEVblog gear and Wurth Elektronik Books.
Also, if you want to get ripped off: https://www.ebay.co.uk/usr/simons_electronics?_trksid=p2047675.l2559
Offline Rick
  • Country: tr
Re: Youtube problem
« Reply #16 on: August 05, 2012, 09:28:48 pm »
It is SP2. It does not automatically upgrade to SP3 like before. But my second computer runs on XP SP3 and it has the same problem. I connect my laptop with Win7 to internet through the same ISP and it works fine.
Online Simon
  • Global Moderator
Re: Youtube problem
« Reply #17 on: August 06, 2012, 05:40:58 am »
I have win7 and running chrome, they have no excuse, as I said in a thread I started either youtube have issues with coping or have changed something due to a panic or as someone suggested the ISP is throttling.
Offline Rick
  • Country: tr
Re: Youtube problem
« Reply #18 on: August 08, 2012, 11:53:42 am »
Nah it was non of those reasons... It was a sound card driver missing... in fact I could not install it. Finally I realized I am using the wrong driver for the wrong card. Now that it is installed youtube works fine. The ISP people told me it may be a driver problem and in fact it is. Sorry to keep you busy with this.
