Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
Circuit Studio
Differential pairs!
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Differential pairs! (Read 4394 times)
Simon
Global Moderator
Country:
Did that just blow up? No? might work after all !!
Differential pairs!
on:
February 01, 2018, 02:16:51 pm »
Right. what do I do? the written documentation is not the most enlightening. the video is second to useless and I'm left wondering what to do.
So I finally worked out how to declare two nets as pairs, I sort of worked out how to route differential pairs but it looks like i must set pins up to be on the right side as the differential router won't automatically swap a layer so that the tracks can cross ?
Logged
voltsandjolts
Supporter
Country:
Re: Differential pairs!
Reply #1 on:
February 01, 2018, 04:05:01 pm »
What bandwidth are you hoping to run your diff pair at?
e.g. for USB full speed you would probably OK with via crossover. For high speed, I dunno, but I'm a pessimist.
Logged
Joel_l
Frequent Contributor
Country:
Reply #2 on:
February 01, 2018, 08:54:37 pm »
I don't think the question was, should you it, as much as it was, how do you get CS to do it.
I played with this a little today, no progress.
Logged
voltsandjolts
Supporter
Country:
Reply #3 on:
February 01, 2018, 10:22:54 pm »
The question is first of all 'should you' and then maybe 'how you' cross a diff pair. I typically do 4 layer boards that are not controlled impedance and do not have high bandwdth diff pairs. I would guess that Simon is in a similar situation. So, this method works for me:
Once you have decided what pattern you want to use for the crossover (one or two pairs of vias & position), place vias and set their nets appropriately. Use vias in both traces to match impedance as best you can and to provide a via pair that the diff route tool can 'snap' to.
Manually route the (very short) crossover section. Manually matching the trace lengths in this short section is not really a chore and not an issue for a low bandwidth diff pair.
Now use the diff pair routing tool to route the long sections of the pair - they will 'snap' to the via pairs of your crossover because you set the nets for those.
Logged
voltsandjolts
Supporter
Country:
Reply #4 on:
February 02, 2018, 09:41:37 am »
For example, matched length / matched via crossovers with layer change and without layer change:
Logged
3db
mars01
ubbut
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Circuit Studio
Differential pairs!
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
