Loading [MathJax]/extensions/Safe.js
Author Topic: Pin type for MISO on slave device in CS?  (Read 4684 times)
Offline daqqTopic starter
  • Country: sk
    • My site
« on: June 08, 2019, 07:54:13 am »
Hi guys,
What value should be assigned to the 'Electrical type' property for a MISO like pin on an SPI Slave device? It will generally connect directly to I/O type pins on a processor/FPGA. Per the default ERC rules, making it an output would cause a warning. It's a tristate really, out of the options available output fits best.
Thanks,
Offline voltsandjolts
Re: Pin type for MISO on slave device in CS?
« Reply #1 on: June 08, 2019, 08:21:38 am »
For pins that are not obviously power, input or output, I use passive.
I'm not saying that's the best answer though!
