Author Topic: Circuit Studio in Wine (Linux)  (Read 9055 times)
Offline ubbutTopic starter
« on: June 14, 2019, 09:38:52 am »
Just letting you know, Circuit Studio does run in Wine.
I used these instructions for Circuit Maker:
https://circuitmaker.com/blog/3-steps-for-installing-circuitmaker-on-linux
There are some minor graphic bugs, nothing serious. Quite usable.
edit: graphic bug when pressing P-P in schematic editor seems to be in the windows version as well ;) So no graphic bug related to wine
« Last Edit: June 18, 2019, 12:01:12 pm by ubbut »
The following users thanked this post: voltsandjolts, ebclr
Offline trevwhite
Re: Circuit Studio in Wine (Linux)
« Reply #1 on: June 17, 2019, 09:37:23 pm »
It dont work that great in Windows, surprised it works in Wine.  :-DD
Offline malagas_on_fire
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #2 on: June 17, 2019, 10:31:01 pm »
Even the circuit maker student version works on Wine, which is suitable for learning purposes and freeware.
Download link from BR school :P
http://docente.ifrn.edu.br/leonardoteixeira/links/instalador-do-circuitmaker-student/view
Update : testing for real on Wine :P
« Last Edit: June 17, 2019, 10:48:13 pm by malagas_on_fire »
If one can make knowledge flow than it will go from negative to positve , for real
Offline voltsandjolts
« Reply #3 on: June 18, 2019, 07:15:16 am »
That is MicroCode CircuitMaker, not at all related to Altium Circuitstudio, Altium CircuitMaker or this forum.
« Reply #4 on: June 18, 2019, 07:19:46 am »
Since my first post I have had a couple of the well known Altium crashes - but surprisingly the program continues to run perfectly. This is for example when importing a CircuitMaker pcb file, without having an other PCB file in the project. I don't know if this is a bug in Windows as well...(I could imagine it is)
« Reply #5 on: June 18, 2019, 08:40:14 am »
Could you post some screenshots of CS in WINE? Just curious to see how it looks.
Does the PCB 3D view work?
« Reply #6 on: June 18, 2019, 09:26:39 am »
I guess it looks the same as in windows.
« Reply #7 on: June 18, 2019, 09:48:34 am »
Thanks for that.
It does look the same, I was expecting some bad looking fonts or such-like.
Good to see CS is usable in WINE, I need to try it.
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #8 on: June 18, 2019, 03:42:44 pm »
Thanks for the info. I though the old circuit maker.... Well in that case thats amazing
« Reply #9 on: July 15, 2019, 01:14:57 pm »
In order to get the .DXF import working, one needs to install TeighaX as described in this post:
https://www.eevblog.com/forum/circuit-studio/create-pcb-outline-from-dxf/
Install TeighaX in the correct wine prefix:
WINEPREFIX=/home/xxx/.wine-circuitstudio/ wine msiexec /i /home/xxx/.../TeighaX_Setup_3.9.0.msi
then follow the instructions in the above post.
