Author Topic: [SOLVED] Global editing of vias  (Read 3985 times)
Offline negativ3Topic starter
  • Country: th
« on: August 16, 2017, 06:48:59 am »
Hi all,
Is there any way to globally edit via dimensions? I want to modify the outer diameter a touch of roughly 50ea in a design.
Or am I stuck editing one-by-one?
Thanks
« Last Edit: August 16, 2017, 07:33:53 am by negativ3 »
Offline voltsandjolts
Re: Global editing of vias
« Reply #1 on: August 16, 2017, 07:28:58 am »
http://documentation.circuitstudio.com/display/CSTU/PCB_Pnl-PCBFilter((PCB+Filter))_CS
For example:
In PCB filter select object=via
In PCB editor window select all 'filtered' objects by pressing Ctrl-A
All vias are now selected
Now open the Object Inspector - change properties as you wish.
The following users thanked this post: negativ3
  • Country: th
Re: [SOLVED] Global editing of vias
« Reply #2 on: August 16, 2017, 07:39:10 am »
Thanks voltsandjolts, perfect.
Offline taydin
  • Country: tr
« Reply #3 on: August 27, 2017, 01:23:13 pm »
I am trying to create a PCB footprint for a transformer and I can't find the PCB filter for selecting all of the pads. Does this filter not work when in library mode?
Real programmers use machine code!
My hobby projects http://mekatronik.org/forum
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: August 27, 2017, 08:42:13 pm »
PCBLib Filter Panel works just fine with the same queries (IsVia, IsPad, etc.).
Seven Transistor Labs, LLC
