Author Topic: TIP: Adding datasheet help (via F1)  (Read 1291 times)
Offline onesixright
« on: April 09, 2017, 09:56:15 pm »
FYI
If you want to add the datasheet to your custom component, double click the component and add under Parameters a paramater with the name HelpURL, the value is the http(s) link to your datasheet.
Now, when you hold your mouse cursor over the component and press F1, ta-da the datasheet loads. Or right click the component and you should see References menu.
Have a look: http://techdocs.altium.com/display/ADRR/Sch_Obj-Parameter((Parameter))_AD
The ComponentLink1Description & ComponentLink1URL also works (shows a Reference menu when right clicking the component).
« Last Edit: April 09, 2017, 10:02:59 pm by onesixright »
The following users thanked this post: Harvs, trevwhite
