Author Topic: Rotate schematic symbol 45 degrees  (Read 1341 times)
Offline negativ3
  • Country: th
« on: June 17, 2020, 11:15:45 am »
Hi all, this is for a decent looking diode bridge. Any hints appreciated, or do I attempt to draw it up myself?
Offline voltsandjolts
Re: Rotate schematic symbol 45 degrees
« Reply #1 on: June 17, 2020, 12:20:28 pm »
Hah, in 3 years of using CS I never realised you could only rotate in 90 degree increments in schematic!
I suppose it makes sense, otherwise you could get in a pickle quite easily, with pin connections not lining up on the schematic 10x10 grid.
« Last Edit: June 17, 2020, 12:28:25 pm by voltsandjolts »
Offline negativ3
  • Country: th
« Reply #2 on: June 17, 2020, 12:37:55 pm »
Yea, sod it, it's easier just to make one as a symbol and lay it out incorporating all four diodes in the pcb as well.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: June 17, 2020, 01:02:54 pm »
How's this?
Seven Transistor Labs, LLC
