Author Topic: Graphics import (vector)  (Read 6801 times)
Offline ubbutTopic starter
« on: July 10, 2019, 01:52:33 pm »
I have read many forum posts about this, and there is also a tutorial by Altium.
However nothing works for me.
Does anyone have a working method of importing vector graphics into Circuit Studio?
thank a lot !
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
Re: Graphics import (vector)
« Reply #1 on: July 11, 2019, 06:04:39 pm »
If you PM me the file I will import it and send it back as an ascii board in a few different sizes (or tell me what physical size you need)
“They Don’t Think It Be Like It Is, But It Do”
« Reply #2 on: July 11, 2019, 06:12:05 pm »
Thanks a lot for the offer. However I often need to import graphics and would like to have a working solution.
How do you do it?
what is an ascii board?
thanks
Offline Pseudobyte
« Reply #3 on: July 12, 2019, 05:59:47 pm »
I would import it using klipper but that is an Altium only script.
Offline voltsandjolts
« Reply #4 on: July 13, 2019, 08:29:58 pm »
You mean vector for PCB artwork right?
What format is your file?
I use DXF and font graphics in CS PCBs with no problems.
Designer has scripts for converting bitmaps to line art, but no scripting in CS I'm afraid.
« Reply #5 on: July 14, 2019, 04:44:02 pm »
importing graphics using fonts kind of works for me, but very complex graphics are getting simplified (sometimes to the extend that it is unusable)
I tried the DXF import. Does not work for me at all. I get the message 'Done' but nothing happens.
This might be due to
- I am running Circuit Studio in Wine
- I have incompatible dxf files
- I am doing something wrong?
Also tried importing .png via the 'image' command, but nothing happens either :(
Can you send me a dxf that works for you?
« Reply #6 on: July 14, 2019, 05:13:24 pm »
Ahh, yes, been there myself. That happens when the DXF importer is not actually installed, but instead of warning you CS just says 'Done'  :palm:
Try this:
https://www.eevblog.com/forum/circuit-studio/create-pcb-outline-from-dxf/
The following users thanked this post: O.B.U.B.
« Reply #7 on: July 15, 2019, 01:15:37 pm »
Awesome! it works !:)
Offline O.B.U.B.
« Reply #8 on: December 29, 2019, 12:20:42 pm »
Working... :-+
kind regards
O.B.U.B.
