Author Topic: Custom shape pad  (Read 1352 times)
Offline plazma
    • Homepage
Custom shape pad
« on: April 08, 2017, 01:36:29 pm »
What is the best way to make custom shape pads?
I made one triangle shaped pad. First I made a triangle with "solid region" to the top layer. Then I inserted one smd round pad inside the trianle.
Pasta region filled only the smd pad so I made also one triangle shaped pasta region.
Any better ways?
