Author Topic: Interactive routing visibility problems  (Read 1063 times)
Offline pisoiu
« on: December 15, 2020, 02:57:29 pm »
I am sorry if this has been discussed here before, I was not able to find it.
While I am doing interactive routing I have some visibility problems. When I choose a net to work on, all other nets/vias disappears from my view, I cannot see them. I can only guess where they are after the shadows they make over the grids. It is very difficult to work this way.
I spent a fair amount of time looking for a solution in settings but no luck so far. How can I change this? In CS tutorials I saw that the other nets/vias/tracks only dim their color, but they do not disappear completely like in my case. I attached 2 pictures, one with normal view, other with interactive routing started.
Offline IanJ
  • Country: scotland
  • Pro EE guy many years ago, now a hobby/home biz.
    • IanJohnston.com
Re: Interactive routing visibility problems
« Reply #1 on: December 15, 2020, 03:49:38 pm »
Go to VIEW tab (on PCB) and at the right hand side of the ribbon set the DIM level slider. You probably have it quite low.
Ian.
Ian Johnston
www.ianjohnston.com
Manufacturer of the PDVS2 & PDVS2mini
Offline pisoiu
« Reply #2 on: December 15, 2020, 09:00:35 pm »
Thanks very much, it worked.
