Hello,
yes, I know this window. But either it doesn't support my requirements or I have not found the right parameter.
For me it looks like I can only set clearance rules between 2 copper-objects. This works as expexted.
But my wish is to set clearance to non-copper-objects (pure unplated hole, board outline).
I want to achieve a result as the top track in the picture (small grid-lines = 0,1mm):
track to hole (Pad0=left) -> >=0,3mm
track to copper-pad (Pad1=right) == 0,1mm
With the clearance-matrix I can change the clearance between track and TH-Pad, I have marked thw changed parameter with red. But this influences both cases:
either I set it to 0,1mm (track on the bottomside of the Pads) -> my track gets to close to the drilled hole (and I get a complaint from the pcb-manufacturer) (middle trace in the picture)
or I set it to 0,3mm -> track <-> hole clearance is ok, but on the whole pcb all tracks have unnecessary clearance to all other TH-Pads (lower trace on the picture)
I search a general rule wich distinguishes between hole-clearance and copper-clearance.
