Author Topic: The digikey supplier link is not working in CS.  (Read 206 times)
Offline limata
« on: October 02, 2019, 09:10:46 pm »
The digikey supplier link used to work but it stops working a while ago. Anybody experiences this? Is there a solution. Here is the error message: " Digi-key: Invalid partner Information".
Thanks
Offline voltsandjolts
Offline floobydust
Re: The digikey supplier link is not working in CS.
« Reply #2 on: October 12, 2019, 07:57:07 pm »
Be careful when you change a component, in Altium it does not properly refresh the other component fields from the Supplier.
Try it as an experiment with CS just to make sure.
edit: I've been burned by this lovely feature only working for the initial part number, supplier fields populated but change the DK part number and old data remains.
« Last Edit: October 12, 2019, 08:03:04 pm by floobydust »
