Author Topic: Interactive routing visibility problems  (Read 5149 times)
Offline pisoiuTopic starter
« on: December 15, 2020, 02:57:29 pm »
I am sorry if this has been discussed here before, I was not able to find it.
While I am doing interactive routing I have some visibility problems. When I choose a net to work on, all other nets/vias disappears from my view, I cannot see them. I can only guess where they are after the shadows they make over the grids. It is very difficult to work this way.
I spent a fair amount of time looking for a solution in settings but no luck so far. How can I change this? In CS tutorials I saw that the other nets/vias/tracks only dim their color, but they do not disappear completely like in my case. I attached 2 pictures, one with normal view, other with interactive routing started.
Offline IanJ
  • Country: scotland
  • Full time EE & Youtuber
    • IanJohnston.com
Re: Interactive routing visibility problems
« Reply #1 on: December 15, 2020, 03:49:38 pm »
Go to VIEW tab (on PCB) and at the right hand side of the ribbon set the DIM level slider. You probably have it quite low.
Ian.
Ian Johnston - Original designer of the PDVS2mini || Author of the free WinGPIB app.
Website - www.ianjohnston.com
YT Channel (electronics repairs & projects): www.youtube.com/user/IanScottJohnston, Twitter (X): https://twitter.com/IanSJohnston
« Reply #2 on: December 15, 2020, 09:00:35 pm »
Thanks very much, it worked.
