Hi everyone, CS just gave me yet another surprise. I add components to schematic and import changes to PCB. The components all get added to the PCB on the top layer as expected but the designators are all on bottom silk and mirrored!?
I try to click and drag to select them to no avail. I could filter for text on bottom layer and select them all with ctrl-A but then I also select all my other designators that I don't want to change. So I hold shift and click every new designator and then use object inspector to change them.
Not sure if this has anything to do with it but I use the .Designator special string on footprints in PCB library for assembly text top and that seems like it still works.
Anyone know why this happens or how to fix it?
While we are at it, anyone know how to set default height and width for designators?
