Author Topic: Who use the VHF for Short Range Devices (here in Europe)?!  (Read 1693 times)
Offline Lord of nothing
  • Country: at
« on: August 21, 2019, 09:16:53 pm »
https://www.bmvit.gv.at/telekommunikation/ofb/marktueberwachung/fsb/funkschnittstellen/fsbld.pdf
For example:
138,200 MHz - 138,450 MHz - Short Range Devices FSB-LD074
On 151Mhz "Band" are Channel for Traffic Lights and Medical Device.
And other for Remote Controlled cranes.
Also on 169Mhz Band are some Short Range Stuff there.  :-//
So who use that Various Freq on VHF for anything?
Made in Japan, destroyed in Sulz im Wienerwald.
Offline Gribo
Re: Who use the VHF for Short Range Devices (here in Europe)?!
« Reply #1 on: August 31, 2019, 10:37:29 pm »
There are certain transceivers from TI that can work in the 169MHz range.
I am available for freelance work.
Offline SWR
  • Without engineering science is just philosophy.
« Reply #2 on: September 06, 2019, 10:27:33 pm »
LoRa covers from 137MHz to 1020MHz.
Check the datasheet of Semtech SX1276.
It covers LoRa and FSK on the same chip.
SX1262 covers LoRa, FSK, GFSK, MSK and GMSK from 150MHz to 960MHz.
You should never go down on equipment!
