Author Topic: Does LoRa require a Gateway?  (Read 192 times)
Online Lord of nothing
  • Country: at
« on: August 12, 2019, 02:06:35 am »
Hi
I am interested in play around with that Module its cheap: https://www.delock.de/produkte/S_12593/merkmale.html
It says the Data are encrypt. Hmm who can decrypt it?  :-//
The point is by Law the output Power is limited that mean I can receive the Data with what ever Antenna I want and that mean I can put a hight Gain Antenna onto a "receiver". When I understand it right its just a one way communication?
Thanks
Made in Japan, destroyed in Sulz im Wienerwald.
Offline Dave_PT
  • Country: pt
    • "O Engenhocas"
Re: Does LoRa require a Gateway?
« Reply #1 on: August 12, 2019, 06:34:52 pm »
Start reading this, it seems a good start.
https://www.instructables.com/id/Introducing-LoRa-
The following users thanked this post: Lord of nothing
Offline StillTrying
  • 100% Brand New and HQ. Thanked: 32768 times
« Reply #2 on: August 12, 2019, 09:22:32 pm »
I asked a similar question a short while ago, after reading https://www.mouser.com/ds/2/761/sx1276-1278113.pdf
I think I know the answer. :)
CML+  That took much longer than I thought it would.
Online devan
« Reply #3 on: August 13, 2019, 02:22:54 am »
So there are two aspects of LoRa:
  • LoRa, the chirp-based RF modulation scheme
  • LoRaWAN, a communication stack that encompasses rules for framing packets at the link layer, managing power levels, authenticating devices and encrypting data
You can use LoRa and ignore LoRaWAN and invent your own rules for when to send packets, how to frame them, and how to validate them. Then you just match spreading factors between your transmitter and receiver and you're good to go, no gateway required.
However, you may want to interoperate with all of the LoRaWAN stuff out there - like being able to make use of other people's receivers (gateways) with better line of sight, plus the ability to get your data routed over the internet to your server, instead of building out all of that infrastructure yourself. Or maybe you don't want to build your own network stack.
In that case, you do need a gateway associated with the LoRaWAN network operator of your choosing. The Things Network has some good documentation on the LoRaWAN side of things:
https://www.thethingsnetwork.org/docs/network/architecture.html
The following users thanked this post: edavid, zucca
Offline zucca
  • EE meid in Itali
« Reply #4 on: August 13, 2019, 05:04:32 pm »
Thanks, LoRaWAN seems to me very close to NB-IoT
Offline Dave_PT
  • Country: pt
    • "O Engenhocas"
« Reply #5 on: August 13, 2019, 06:26:39 pm »
Kind of...
But I think that NB-IoT will be a game changer to a real network of IoT.
LoRaWAN use LoRa modulation and (I think) the SEMTECH is the only one that produce the radios (they invented the LoRa). So anyone depends of SEMTECH wills, delays, etc...
Offline zucca
  • EE meid in Itali
« Reply #6 on: August 13, 2019, 07:46:54 pm »
I am wondering if the new NB-IoT devices will get an IPv6 assigned.
Scary.
