Author Topic: GARMIN watch - ConnectIQ-Watch-IoT - Microsoft Azure Platform  (Read 1318 times)
Offline Peter Gamma
Re: GARMIN watch - ConnectIQ-Watch-IoT - Microsoft Azure Platform
« Reply #25 on: January 23, 2020, 09:08:06 pm »
There is also a discussion how to stream ANT+ sensor data to MATLAB in the MATLAB cummunity:
https://www.mathworks.com/matlabcentral/answers/142677-capturing-heart-rate-from-usb-ant-dongle-and-chest-strap
No easy, low-cost and high quality solution to this date. Although such solutions are possible.
Offline Peter Gamma
« Reply #27 on: January 24, 2020, 11:16:34 am »
For a live-stream of sensor data from a GARMIN watch to MATLAB, those options are / were available:
1.
https://livetracking.io/
which according to Niels Kieling
   a. «yes, this should work»
   b. and «was a free and open source» service
2.
Dave Does Demos Demo solution (Dave Lusty who works for Microsoft UK)
https://forums.garmin.com/developer/connect-iq/f/discussion/209439/eventhubapp
which can stream sensor data from a GARMIN watch to Microsoft Power BI. But streaming from  Microsoft Power BI to MATLAB only works with MATLAB production server, which is according to the MATLAB community «expensive». For a price request a quote.
3.
A Linux MATLAB version running in a virtual box in windows
https://www.eevblog.com/forum/cloud-computing/live-stream-from-garmin-watches-via-ant-stick-virtual-box-(evtl-coud-iot)/
this option has no streaming server and uses an ANT+ stick. There is no smartphone buffer to this system.A direct sensor stream without interruption is necessary betwen a GARMIN  watch and a PC or mini PC:
« Last Edit: January 24, 2020, 12:09:12 pm by Peter Gamma »
Offline Peter Gamma
« Reply #28 on: January 24, 2020, 05:47:15 pm »
Here is a Lab Streaming Layer (LSL) Tutorial for Windows:
https://ws-dl.blogspot.com/2019/07/2019-07-15-lab-streaming-layer-lsl.html
Is it possible to integrate LSL into Microsoft Power BI? Is LSL streaming sensor data from Microsoft Power BI to MATLAB possible ?
Offline Peter Gamma
Offline Peter Gamma
« Reply #30 on: January 24, 2020, 10:18:31 pm »
The MATLAB forum is open minded. You don t need MATLAB to post there.
In the XDA Developer forum, at least eight helpful posts are necessary before it is possible to be a developer there. I miss for instance a company independed GARMIN watch section there. I tried to create one, but failed because I created too little helpful posts to this date.
Offline Peter Gamma
« Reply #31 on: January 25, 2020, 08:32:31 pm »
How to Use the expensive MATLAB Production Server Interface for Microsoft Power BI Software:
https://www.mathworks.com/videos/how-to-use-matlab-production-server-interface-for-microsoft-power-bi-software-1537959094440.html
for MATLAB Production Server request a quote from MATLAB.
Offline Peter Gamma
« Reply #32 on: January 26, 2020, 02:34:30 pm »
A straightforward solution would be:
1. Labstreaming layer support for the GARMIN watch
2. a Windows Python Library for the GARMIN watch
where every user is free which application to choose for his needs.
Offline Peter Gamma
« Reply #33 on: January 26, 2020, 06:06:19 pm »
EEVblog – No Script, No Fear, All Opinion :-+.
