Author Topic: Live-stream from Garmin watches via ANT+ stick & virtual box (evtl. coud, IOT)  (Read 746 times)
Offline Peter Gamma
to MATLAB, Python & other Desktop applications
I continue the thread from here:
https://www.eevblog.com/forum/cloud-computing/garmin-watch-connectiq-watch-iot-microsoft-azure-platform/
and continue here with the part which is not
GARMIN watch - ConnectIQ-Watch-IoT - Microsoft Azure Platform
     but
GARMIN watch- ANT+ stick- virtual box
to keep those two path separate.
Is it possible to create a linux virtual box which can run independendly as a Linux OS, but also as a virtual box running in windows, for a GARMIN watch, which contains all the components for a live-stream to MATLAB, Python & other Desktop applications?
The size should be not more than 2GB, so that it can run on a IntelĀ® Compute Stick STK1A32SC:
https://ark.intel.com/content/www/us/en/ark/products/91064/intel-compute-stick-stk1a32sc.html
as well as on a Jumper EzBook 3 PRO:
https://de.gearbest.com/laptops/pp_647765.html
A virtual box could become a community project which contains all the sensor tables helpful for GARMIN watches.
Offline Peter Gamma
A linux virtual box running in windows with sensor tables and all the software necessary to stream to MATLAB, Python or other deskop applications.
A linux virtual box running in windows 10 of e.g. Jumper EzBook 3 PRO, which makes it not necessary anymore to install Ubuntu. All software for streaming integrated in a virtual box.
But how can sensor data from a linux virtual box running in windows be streamed to the host windows 10 operating system?
edit:
This is not necessary. MATLAB is also available for LINUX and MATLAB can be installed in a LINUX virtual machine running in windows. No streaming to the host windows 10 operating system necessary.
« Last Edit: December 27, 2019, 12:29:38 pm by Peter Gamma »
Offline Peter Gamma
i.e. through a streaming server. livetracking.io had an integrated open-source streaming server.
Which streaming server could be helpful to stream sensor data from a linux virtual box to the host windows operating system?
Offline Peter Gamma
An alternative to Jumper EzBook 3 PRO with
with 4 GB RAM  & 64 bit OS (minimal requirement for most Matlab editions)
is the Trekstor SURFBOOK E11B
http://www.trekstor.de/products/notebook/detail-notebook/product/SURFBOOK%20E11B-CO.html
with Ubuntu 18.04 und Mate Desktop
https://www.heise.de/forum/c-t/Kommentare-zu-c-t-Artikeln/Aldi-Notebook-im-Test-Medion-Akoya-E6246-mit-256er-SSD-fuer-400-Euro/Trekstor-E11B-CO/posting-33859257/show/
Offline Peter Gamma
There are also newer Mini 10 PC sticks with 4G RAM & Windows 10 64 bit (minimum for newer MATLAB versions):
https://www.aliexpress.com/item/32826816000.html?spm=a2g0o.cart.0.0.206d3c00MwHGDE&mp=1
and USB Type-C:
https://www.aliexpress.com/item/32852962272.html?spm=a2g0o.cart.0.0.206d3c00MwHGDE&mp=1
Did someone test those newer devices with Linux?
« Last Edit: December 18, 2019, 08:39:13 pm by Peter Gamma »
Offline Peter Gamma
There are / where so many projects with an ANT+ and Windows for a live-stream from a GARMIN watch:
1. there was a live-stream solution from old-man biking:
https://www.thisisant.com/forum/viewthread/544/
2. there is a live-setup in GoldenChetaah:
https://groups.google.com/forum/#!topic/golden-cheetah-users/Gn2fOxUqTFk
4. There was livetracking.io
https://github.com/PeterGamma/What-happened-to-livetrack.io-/blob/master/README.md
6. There where other options for a live-stream which are not available anymore:
8. GARMIN watch - ConnectIQ-Watch-IoT
which requires Microsoft Power B and the Microsoft Azure Platform
https://forums.garmin.com/developer/connect-iq/f/discussion/209439/eventhubapp
9. Ant+ USB with LabVIEW
- https://www.thisisant.com/forum/viewthread/7035/
Is there a project with ANT+ windows code tables available, which can be modified? To have a live-streaming solution in LINUX for the only reason that there are no windows ANT+ code tables available is complicated.
« Last Edit: December 18, 2019, 10:52:03 pm by Peter Gamma »
Offline Peter Gamma
I m a person with skills in scripting and debugging of MATLAB scripts and scripts of other PC applications. For me personally, to make this project real takes time.
For the time being, I let go of a real-time stream, even though it s interesting, and go back to the csv import method from GARMIN CONNECT without a live-stream.
« Last Edit: January 04, 2020, 01:36:27 pm by Peter Gamma »
Offline Peter Gamma
I miss a sports watch which is really smart.
I miss a sports watch with an easy to use and contemporary windows 10 interface.
I miss a live-tracking service which is simple and smart, instead of a live-tracking service for data nerds:
https://livetracking.io/
which stops as soon as someone comes which is interested in that service.
https://livetracking.io/ was near to that. And in my few, it could be brought there quiet easily.
I miss a live-streaming service for professionals.
Dave Lustys  ConnectIQ-Watch-IoT - Microsoft Azure Platform solution is near to it. I miss support  for more watches instread of support only for new and expensive watches, and I miss support not only for  the Microsoft Azure Platform and Microsoft Power BI, but also for other platforms and applications.
« Last Edit: January 01, 2020, 09:22:04 am by Peter Gamma »
Offline Peter Gamma
Darren Hague s project is also ready to go  :).
https://www.thisisant.com/forum/viewthread/6665/
https://github.com/dhague/vpower
But it needs a live-stream without interrupton to an ANT+ stick. In my view, just for indoor activites, that's fine.
Offline Peter Gamma
When you are ready to carry arround a Jumper Book 3 for 24 * 7, then Darren's project is 24 * 7 ready to go :).
Offline Peter Gamma
Jumper EZBOOK 3 PRO:
with more than thousand costumers which are happy with it, I'm one of those  :).
« Last Edit: March 15, 2020, 10:54:49 am by Peter Gamma »
Offline Peter Gamma
This real-time data aquisition system consists of:
- Jumper EZBOOK 3 PRO
- Vivoactive 3
- Polar OH1
- Stryd Foot Pod ( no calibration needed. I have also a GARMIN foot pod, but unfortunately it is not calibrated to this date)
- Darren HagueS ANT+ Virtual Power
- Virtual Box running in Windows with MATLAB
- no Microsoft Azure Platform, no GARMIN connect IQ, no Watch-IoT, but heavy. But not as heavy as an ADINSTRUMENTS channel recorder equipement and not as expensive as an Equivital system, and longer warrranty time.
« Last Edit: March 15, 2020, 01:04:14 pm by Peter Gamma »
Offline Peter Gamma
It is also possible to take a Moximonitor ANT to Serial Converter instead of a ANT+ stick and a virtual Box running in Windows with Python ANT+:
https://www.moxymonitor.com/product/ant-to-serial-converter/
Still a heavy equipement.
« Last Edit: Today at 08:03:03 am by Peter Gamma »
Offline Peter Gamma
Pairing this setup with this mini PC and a battery pack:
https://de.aliexpress.com/item/32852962272.html?spm=a2g0s.9042311.0.0.27424c4dvJApcD
but is it robust and stable?
Offline Peter Gamma
7 inch Windows 10 tablets are rare to find. But what about building up one with a 7 inch display and a Windows 10 mini PC?
https://de.aliexpress.com/item/32832814420.html?spm=a2g0s.9042311.0.0.27424c4dvJApcD
