Poll
Which Cloud Provider(s) do you (or your company) use or plan to use?
Amazon Web Services
20 (35.1%)
Alibaba
1 (1.8%)
Google Cloud platform
6 (10.5%)
IBM Cloud
1 (1.8%)
Dell Cloud Platform
0 (0%)
Microsoft Azure
12 (21.1%)
I prefer sunshine over Cloud.
17 (29.8%)
Total Members Voted: 40
Author Topic: Which Cloud Service do you (or your company) use or plan to use?  (Read 2973 times)
Offline mrpackethead
  • D Size Cell
Re: Which Cloud Service do you (or your company) use or plan to use?
« Reply #25 on: May 31, 2019, 08:30:30 am »
I'm helping people move away from the cloud at the moment, particularly AWS, after they have been burned. I'm a cert AWS architect for ref so if that's a recommendation then I don't know what is  :-DD
I'm AWS certified as well,  but the certification just means you've paid $300 and can pass the exam.    I've been moving services into the cloud, after organisations could'tn keep on premise going reliably.
We've
seen cost models escalate to 3x the initial cost and at £2m+ to start with that's not a good deal.
[/quotes]
That just means you had no idea of what your load was, what you were building.
Also the staffing required does not decline in cost or quantity.
See above point. Being certified means nothing.
Online bd139
« Reply #26 on: May 31, 2019, 10:05:08 am »
I'm not talking about on-prem but traditional hosted DC infrastructure migrating to AWS which is the market I sell myself to. On-prem is usually a mishmash of MSP managed and semi-competent admin crud that needs consolidation rather than stacks of kit. The workload impact profile is usually entirely different on AWS compared to infrastructure you built yourself which is where cost models fall flat on their arses. The last platform I moved back was 150k requests/second HTTP and they couldn't get the 90th percentile latency back down below 700ms on AWS because of the sheer shitty price/performance ratio. Back to a couple of stacked C7000s it went.
Incidentally my certification was a stab at the certification process which was so easy it is pointless. Also the trick on the market is to get someone else to pay for the training which you mostly just sit on ebay through buying test gear then pay for the exam then leverage that to increase the daily rate.
Offline windsmurf
« Reply #27 on: June 01, 2019, 08:45:11 am »
I came away more impressed with Azure after my 2 day visit to the Microsoft Tech Center, as were our software architects and machine learning guys.
Some items of note I found superior to AWS:
AutoML:  Will test run your dataset against about 100 different deep learning models/algorithms to find the model with the best convergence.
Cosmos DB: More friendly to database admins and developers than DynamoDB, with more features (like SQL-like query available)
        https://db-engines.com/en/system/Amazon+DynamoDB%3BMicrosoft+Azure+Cosmos+DB%3BMongoDB
Bot Service: Easily integrates with Azure cognitive services (voice to text, image ID/classification, faceID, translation and language detection, etc); build just one bot and deploy it automatically to webchat, Facebook, Line, Skype, Teams, Kik, Slack, etc.  No customization for each channel needed!
https://dev.botframework.com/
« Last Edit: June 01, 2019, 09:28:15 am by windsmurf »
  • D Size Cell
« Reply #28 on: June 01, 2019, 09:15:09 am »
Microsoft and Amazon are both very good at impressing people and the whole point of why they have you at their tech breifing centers is to impress you.  They will be very pleased you have drunk the cool-aid.
Its horses for courses.   I really like using Lambdas, and the API gateway. mostly what i'm doing is small stuff.  What does concern me is that it locks me in too one particular vendor.  Could i build what i'm doing with the same level of resilance and security for the price.
Online bd139
« Reply #29 on: June 01, 2019, 09:45:07 am »
Your latter point is what worries me. Once you’ve glued everything into lambda you’re SOL if you want to move away. I only recommend the IaaS and portable services when I architect anything for the cloud.
Offline windsmurf
« Reply #30 on: June 01, 2019, 09:49:22 am »
Yes agreed... a thorough POC testing is needed to vet out the truth.
Lambda's are fantastic, especially the way in which it integrates with all other AWS services.   I thought about using open-source serverless in a docker container within EC2 for portability to other clouds or on-prem... but why?  It'll just cost more and lacks seamless integration with all the other AWS services.
Forgot to mention Azure IoT and IoT Edge... seems to be more refined than AWS IoT/Greengrass.  Certainly seems to have better acceptance from manufacturers, at least the ones I know about...
Offline windsmurf
« Reply #31 on: June 01, 2019, 09:56:09 am »
Its ultra-cheap... but yes you get locked in...
its the same story.... pick 2 (cheap, transportable/resilient, performant)
Online bd139
« Reply #32 on: June 01, 2019, 01:10:11 pm »
It’s not even cheap though. The price curve is pretty flat and then goes straight up your butt.
I’ve seen a couple of startups nearly hose themselves with a finger in the air cost estimate.
Offline madires
  • A qualified hobbyist ;)
« Reply #33 on: June 01, 2019, 01:39:55 pm »
You could read that also as "you'll train our AIs for free". >:D
Online bd139
« Reply #34 on: June 01, 2019, 01:57:15 pm »
All the AI offerings are a joke so I wouldn’t worry. I know a big fintech that went through them all spending millions for basic risk management stuff and came to the conclusion a pigeon pecking on a yes/no button had the same outcome quality.
Offline windsmurf
« Reply #35 on: June 01, 2019, 08:33:14 pm »
Well, yes overall its not going to be cheap, since you'll need miscellaneous services other than just lambda... our spend on lambda is less than 1% the cost of our spend on EC2, which is amazing considering how much we use lambda...
Offline windsmurf
« Reply #36 on: June 01, 2019, 08:57:01 pm »
The canned AI model offerings from cloud providers are too generalized, so they won't give good results on everyone's specific datasets.
Our machine learning team regularly avoids using cloud services for any model training/tesing due to high cost.
Good guide for DIY deep learning setup here:
https://timdettmers.com/2019/04/03/which-gpu-for-deep-learning/
  • D Size Cell
« Reply #37 on: June 02, 2019, 02:32:30 am »
To a point.  The databases that the lambda connect to could be easily migrated to.  MySQL = MySQL.     The object store ( S3 ) coudl be done with something else.       I'm using Python for my lambdas.    I'd have to investigate what kind of API you could stick in front of them, to make them lambda like.         At least for my use case, the costs are not crazy.    I'm in the league of a few thousand requests per day,   not 100,000/sec
Offline guenthert
« Reply #38 on: June 06, 2019, 03:42:03 pm »
I do have a large print of a sticker I saw hanging in my cube.
This one
There are no utilities, just someone else's generator.
Online bd139
« Reply #39 on: June 06, 2019, 03:50:37 pm »
Solar panels?
