Author Topic: 0.2 - 8.8 GHz Receiver Froint End and Frequency Extension Module  (Read 15163 times)
Offline samihawasliTopic starter
Have you ever wanted to extend the frequency range of your low frequency test equipment, receivers, or software defined radios well into the GHz range without spending exorbitant amounts of money on RF test equipment? Save your money and check out our low cost 0.2 – 8.8 GHz receiver front end module capable of extending the functionality of your equipment up to 8.8 GHz. A simple block diagram of the receiver is attached below and some of the features include:
•   RF Bandwidth of 0.2 – 8.8 GHz
•   IF bandwidth of 10 – 110 MHz with a max instantaneous bandwidth of 100 MHz
•   Average conversion gain of 40 dB and noise figure of 3.9 dB.
•   Includes a continuous wave output port capable of producing frequencies between 35 MHz – 8.8 GHz.
We are currently looking for backing for our Indiegogo campaign in order to transition the prototype to mass production. All the funds raised will go towards the Bill Of Materials (BOM) costs associated with the purchasing of the all the ICs internal to the receiver, the PCB fabrication, and assembly. If you pre-order a unit through the Indiegogo campaign, you will receive a 10% discount on the original list price.
Check out the campaign here: https://www.indiegogo.com/projects/0-2-8-8-ghz-receiver-front-end#/, and our demo videos on the product homepage here: https://dgrfproducts.com/0-2-8-8-ghz-receiver-front-end-with-added-cw-output/. Download the attached datasheet to get the full performance specifications.
Thank you very much. We are happy to address any questions you may have and we appreciate your support and help in spreading the word about our campaign! Apologies for the shameless plug.
« Last Edit: July 16, 2022, 03:00:04 am by samihawasli »
Offline Gerhard_dk4xp
Re: 0.2 - 8.8 GHz Receiver Froint End and Frequency Extension Module
« Reply #1 on: July 16, 2022, 08:21:59 pm »
Too late. I got this morning the first 10 boards of my dual conversion
down converter from 5-16 GHz, depending on the first mixer.
Needs external source for 1st. LO;    2nd LO has an internal
multiplier from 100 MHz. Makes heavy use of SAW filters
and delivers 2 MHz BW for my TimePod phase noise meter
and the SDR. Sources will be published.
:-)  Gerhard
