Author Topic: PCB Rax - An easy to use circuit board holding system  (Read 2801 times)
Offline rthorntnTopic starter
« on: April 29, 2015, 08:18:48 am »
Looks good, I like the price, thoughts?
https://www.kickstarter.com/projects/1428014401/pcb-rax-an-easy-to-use-circuit-board-holding-syste
$1930 pledged of $25000 goal.
Offline SL4P
  • There's more value if you figure it out yourself!
Re: PCB Rax - An easy to use circuit board holding system
« Reply #1 on: April 29, 2015, 08:47:15 am »
Rewards are a bit strange.
Makers pay $10 more than the Early Birds, and get the same reward a month later ?.
or am I missing something?
Don't ask a question if you aren't willing to listen to the answer.
Offline miguelvp
« Reply #2 on: April 29, 2015, 08:55:05 am »
Kickstarters usually work that way so you are better off getting the Early Bird than not.
As opposed to first adopters of some tech that usually pay more to get it first, which is your standard sales model.
Offline JBaughb
« Reply #3 on: April 29, 2015, 09:40:03 am »
Honestly, I could never use it. The posts on the sides get in the way of effectively using a soldering iron. But, to each his own.
