Author Topic: Dr Duino Arduino Hardware Debugging Tool  (Read 2493 times)
Offline firmwareengineerTopic starter
« on: October 01, 2014, 01:54:10 am »
Hi everyone!
I launched my kicstarter campaign about 2 weeks ago, its called Dr.Duino and is a arduino hardware debugging tool which can also be used as a learning tool without the need for a bread board.
Here is a link to the live Kickstarter http://kck.st/1oSCIWD
It has some really cool features like the ability to break the connection with the board above and the board below. You are then able to reroute the signal out through the dr Duino board to help you identify hardware vs firmware issues. I also added an external reset button which wont get covered by the board above and a lot of other items.
whatcha think?
I created it because while developing another project (called Orbis) I got tired of the typical Arduino pain points.
 http://www.eetimes.com/author.asp?doc_id=1323948
« Last Edit: October 01, 2014, 02:15:11 am by firmwareengineer »
