I would say it simply not good enough for the price point. Why would you want waste so much money on toy tool that cannot do even one job well? I would better buy some specialised services or buy dedicated machines to do the job right and cheaper.
From material one can read that it cannot mill boards, it will blind you and others around it with laser, it stinks with molten plastic, it takes up much space, it needs adjustments via SW, ...
Just look at milled PCB pictures to get idea of the beast quality you can get out of this machine. Not only it is very slow, quality is also lacking. You have to dick around with it for half day to get PCB that is neither quality milled, nor with solder mask, nor accurate, nor even fast. What is the point in that?
There are few shots of drill - it is a Makita hand tool of sorts.
Can anyone identify the model? It is Makita Rt0701C Compact Router. Is it any good for a mill purposes?
I wisk them good luck, but please be realistic.
Boxxy, you again?
Was this an earlier project? Can you share the link?
