Author Topic: World's First Open Face Mask, UV-C, Air Curtain  (Read 3742 times)
Offline FrankBussTopic starter
    • Frank Buss
« on: August 04, 2020, 10:50:45 am »
See here for the Indiegogo campaign.
First formally there is a problem with the video. He says at 1:15 that it kills 99.99999% and suggesting an endless number of 9s, so basically nearly all, but the campaign text says 99.99%. But he is no scientist, has only a bachelor of fine arts, so that explain this inaccuracy. Of course, even 99.99% is very unlikely. While UVC light kills viruses, I don't think that the the small battery and the lifetime of 8 hours suggests allows light strong enough to do this. For example a study shows, that UVC light can kill 99.9% viruses, but it needs 25 minutes exposure time for this percentage, and still 8 minutes for 90%. And I'm sure the light source was much more powerful, but I didn't read the study details.
Another problem is the air curtain. Again, I guess it would need to be very powerful to provide such protection, which is unlikely that the device can do it, and additionally I guess the turbulences because of the near irregular face wouldn't allow a good air curtain. And what air do you breath? Sure, the air curtain might not contain viruses, but the air coming in from the sides still have it. There is no way it could shield you 99.99% and at the same time provide enough air to breath.
It is not totally BS like the free energy scams and looks plausible if you don't think too deep about it, but I guess it would provide only very low protection, like it kills less than 1% of the viruses you breath in.
Offline thm_w
  • Non-expert
Re: World's First Open Face Mask, UV-C, Air Curtain
« Reply #1 on: August 04, 2020, 08:54:55 pm »
Aren't those the same "high efficiency micro blowers" we saw in the airring micro cpap. What are the chances they can actually sustain the full lung capacity of a person breathing normally (7 L/m).
Here is your study full text link: https://www.nature.com/articles/s41598-020-67211-2
The 25 minute and 8 minute were referring to maximum safe exposure:
Based on the beta-HCoV-OC43 results, continuous far-UVC exposure in occupied public locations at the current regulatory exposure limit (~3 mJ/cm2/hour) would result in ~90% viral inactivation in ~8 minutes, 95% in ~11 minutes, 99% in ~16 minutes and 99.9% inactivation in ~25 minutes.
So in a shielded area, exposure could be higher and times could be reduced, if that were possible power wise (probably is not).
The viral solution was collected from the BioSampler after running through the aerosol chamber while being exposed to 0, 0.5, 1 or 2 mJ/cm2 of 222-nm light.
Measurements using the silicon photodetector indicated an exposure intensity of approximately 90 μW/cm2 across the exposure area. The chamber is equipped with a reflective aluminum surface opposite of The exposure window. As in our previous work with this chamber23, the reflectivity of this surface was approximately 15%. We have therefore conservatively estimated the intensity across the entire exposure area to be 100 μW/cm2. With the lamp positioned 22 cm from the window and given the 20 seconds required for an aerosol particle to traverse the exposure window, we calculated the total exposure dose to a particle to be 2 mJ/cm2
So the optical power was ~50mW to hit a 4L area?
UVC LED efficiency is ~5%, mercury lamps up to 30%.
https://iuva.org/resources/2018_IUVA_Americas_Conference/Technical-Proceedings/LEDs%20and%20Other%20UV%20Sources%202/McKain_Molly-UV-C-LED-Devices-and-Systems-Current-and-Future-State.pdf
https://www.sciencedirect.com/science/article/abs/pii/S0043135416308697
Online Marco
« Reply #2 on: August 04, 2020, 09:29:13 pm »
Nah, probably just centrifugal fans.
Simply so you don't breath a hole in the curtain I'm going to guess you'd need a couple hundred litre per minute. So say 10+ CFM. Not outside of the realm of possibilities, but that's quite a bit of fan and quite a bit of air to sterilize.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #3 on: August 05, 2020, 12:17:00 am »
patent pending... i've heard that alot.. how long the battery going to last? there will be a lot of technical explaining to law enforcer in case their decide to stop you from entering premises... how to check body temperature? on the cheek? UV light is hot, be ready to become a suspect if law enforcer (braindead one) insists on forehead... $150? thats worth 100-500 passive and proven not battery limited masks/3-layer/PM2.5 etc that every law enforcer recognize... if the law says its technically inadequate, then $150 is gone.
« Last Edit: August 05, 2020, 12:19:35 am by Mechatrommer »
Offline robca
« Reply #4 on: August 08, 2020, 06:10:06 pm »
Campaign is under review
And that's a good thing. There are so many red flags with this, that is clear only someone with no biology and aerodynamics background could have though of it
Offline Haenk
« Reply #5 on: November 12, 2020, 12:32:10 pm »
A 99.9% removal of viruses or bacteria is pointless. 0,1% of 10 billion are still plenty.
(This is also the reason why you should not use household cleaner with claimed removal of bacteria and viruses - you might kill most of the "easy to handle" stuff, while paving the way for the resistant stuff to reproduce even faster.
Offline thm_w
  • Non-expert
« Reply #6 on: November 12, 2020, 08:17:25 pm »
Not pointless, reduced viral load means less symptoms and less chance of getting sick.
"A model of African swine flu virus shows a clear dose-response relation between the infecting dose and disease in the animal"
https://www.bmj.com/content/369/bmj.m1728
https://www.vaccines.gov/basics/types
Offline S. Petrukhin
  • Country: ru
« Reply #7 on: November 15, 2020, 06:21:47 pm »
Masks will kill humanity along with antiseptics and antibiotics.
Medicine is negligible in the fight against viruses. Most recently, pneumonia was treated with a dose of penicillin 1000 (!) less. Viruses gain the ability to surpass protection faster. They can only be defeated by their own immunity, which has been destroyed for years by people's means of protection.
By protecting ourselves from small doses of infection with a mask, we turn our immune system into an incapable one.
The human body is so arranged: what is little used and not needed-atrophies and becomes ineffective.
So far, only vaccination has been able to defeat epidemics.
Pharmaceutical companies will never make an effective medicine - they do not benefit from people being healthy.
And sorry for my English.
Offline thm_w
  • Non-expert
« Reply #8 on: November 16, 2020, 09:44:16 pm »
:palm:
https://en.wikipedia.org/wiki/Pfizer
  • Country: ru
« Reply #9 on: November 16, 2020, 11:48:26 pm »
:palm:
What did you want to say? This company has been around for many years like many others, but you wear a protective mask, isn't it?
