Author Topic: IGG RFID blocking wallets  (Read 3098 times)
Offline wilfredTopic starter
« on: December 19, 2013, 06:48:20 am »
« Last Edit: August 21, 2018, 10:06:55 am by wilfred »
Offline Psi
Re: IGG RFID blocking wallets
« Reply #1 on: December 19, 2013, 09:16:08 am »
Google "Faraday cage" to find the answer
Offline Rerouter
« Reply #2 on: December 19, 2013, 11:24:43 am »
1. take a standard wallet.
2. glue or sew on a metallic foil covering everything on the outside but the zipper,
3. profit much like this kick-starter probably will
or in this case they most likely will be adding the foil during the bonding stage so it sits between the 2 walls of the outside of the wallet, theoretically this leaves a small gap but still lives up to its name,
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #3 on: December 19, 2013, 11:34:02 am »
All you need is a sheet or ring of copper or ali foil, or a credit-card sized piece of thin copperclad PCB material. RFID works via the magnetic field, and a solid conductor will introduce enough eddy-current loss to prevent data transfer.
A faraday cage is NOT what's required- this protects against electrostatic fields.
Day Job: Mostly LEDs
Offline Psi
« Reply #4 on: December 19, 2013, 11:38:51 am »
ThinkGeek lied to me, i find this most disturbing.
