Author Topic: Chinese HackRF Clone on Indigogo  (Read 6213 times)
Offline DomesticHacks
    • DomesticHacks
« on: December 08, 2014, 06:45:32 am »
https://www.indiegogo.com/projects/hackrf-blue
Don't know how to think about this.
Interesting projects, tipps and tricks (in German).
DomesticHacks on YouTube: https://www.youtube.com/DomesticHacks
Offline mcinque
  • I know one thing: that I know nothing
Re: Chinese HackRF Clone on Indigogo
« Reply #1 on: December 08, 2014, 10:57:57 am »
It looks like the $40 option just gets you some accessories. If you want an actual board it's $200.
Definitely. At a first look I thought was 40 for all the items in the picture. Images like those generate a little bit of confusion.
I'm basically still a rookie and because of this, even with the best intentions, I often say bullshits
Offline idpromnut
« Reply #2 on: December 08, 2014, 06:12:54 pm »
Interesting… I was in the process of adjusting the HackRF design to work with OSHPark's 4 layer PCB stack up. The parts cost that I had put together for 1 unit (minus the PCB cost) was 121$ CDN (and the board cost @ OSH Park was 120$ for 3 boards).
Offline Lightages
  • Canadian po
« Reply #3 on: December 08, 2014, 06:24:04 pm »
They mention using it to read a 115kHz RFID card, but HackRF only works down to 10MHz without an RF up converter.
Offline idpromnut
« Reply #4 on: December 08, 2014, 06:28:59 pm »
I found this odd as well.  But apparently they have tested this and it works. Perhaps someone with a HackRF could give some input if the original can do this as well?
Offline Lightages
  • Canadian po
« Reply #5 on: December 08, 2014, 08:55:51 pm »
They would have to use an RF upconverter but they don't say they used one. It is a bit misleading.
