Author Topic: Teardown of a iRBeacon  (Read 5008 times)
Offline 97hilfelTopic starter
« on: February 12, 2016, 11:05:10 pm »
Hello everybody, I don't know precisly if Im right here, but ok.
Im currently trying to reversengineer a irbeacon.me, Indigogo site:www.indiegogo.com/projects/irbeacon-smarter-remote-for-a-smarter-home/, not
because I want to sell my own, because it is crap and works with a delay of like 2 secs.
So I took one of thes units apart and I found a bluetoothmodule with this text on it:
CSR
1010 (last 0 might be a "Q")
A05U
419AG
Now I'm struggeling with identyfying the bluetoothmodule on there, can somebody please help me?
Currently Im trying to trace all the lines but can't do that because I still didn't got my solderingstation to desolder the BTModule and the battery case.
Thanks for the help
Felix
PS Immages will follow as soon as I get them from my phone to my PC so maybe 10 or 20 minutes
Online ataradov
    • Personal site
Re: Teardown of a iRBeacon
« Reply #1 on: February 12, 2016, 11:12:30 pm »
It is obviously made by CSR - www.csr.com. Look for whatever information you can find there.
Also
We are pleased to announce that as of August 13, 2015, Qualcomm Global Trading Pte. Ltd., a subsidiary of Qualcomm Incorporated, has completed its acquisition of CSR plc.
So good luck finding any documentation :)
Alex
« Reply #2 on: February 12, 2016, 11:16:50 pm »
Already tried to find something there but I did not find something there...
Got now the Complet connection of the Programmingheader...
Online ataradov
    • Personal site
« Reply #3 on: February 12, 2016, 11:25:50 pm »
They are not known for being hobby-friendly. I'm pretty sure they will need an NDA before they will give you anything. And now being part of Qualcomm, it will get even worse.
Alex
« Reply #4 on: February 13, 2016, 12:03:01 am »
Got now my pictures (finally) from my phone to my pc and I have to link them in from my One Drive because they are to big...
Here is the link to the folder: http://1drv.ms/1TXKtNI
Online ataradov
    • Personal site
« Reply #5 on: February 13, 2016, 12:05:54 am »
ATMega328 makes me think that this thing has some Arduino roots.
Have you tried to read out the firmware? Is device locked?
Alex
« Reply #6 on: February 13, 2016, 12:17:53 am »
I think so too.
I tried but havent got there... the Programmerheader has a pretty small pin pitch and I
A) Don't have a connector for it and
B) Its hard to connect it to my AVR ISP II without shorting out everything...
Offline Wilksey
« Reply #7 on: February 13, 2016, 10:33:30 pm »
The pin header doesn't look that small?
The device is a module, don't worry about the chipset, it's a CSR chipset alright, but it's pre-installed on a module, are there any identifiers on the module?
Look for a BT LE module on ebay and I expect you will find it.
I expect the 328 runs a arduino sketch which talks to the BT unit over AT commands or HCI, or something else, and then modulates an IR signal out of the IR LED
It looks to essentially be a BT LE to IR translator
« Reply #8 on: February 13, 2016, 11:10:06 pm »
With the possibilities I got at home I'm already struggling with the 50mil connector. The whole thing is about 30x30mm big.
On the Module itself not exept the labes on the labes on the pins, and a label on the PCB: "BT_4.0" well... helps not so much.
I would be happy if I could get a pinout diagramm for this module... I got the power supply and the UART bus pins, I hope I get my solderingstation soon so I can attach there a few cables and read out that protocoll.
Thats the exption I got to... but I hoped to find in there something like a D21 or a PIC...
Offline Wilksey
« Reply #10 on: February 15, 2016, 06:03:34 am »
Could it be something like:
http://www.asix.com.tw/products.php?op=pItemdetail&PItemID=139;76;117
Have you done a Google search for BT LE module or CSR 1010 Module?
The first one "hits the nail on the head" (literally translated from ther german). I actually looked on google and on the csr website for it but couldnt find it...
Thanks
Gesendet von iPhone mit Tapatalk
Offline Wilksey
