That's not a 3D printer - this is a 3D printer !!
no no no. this printer is just another that printer, specifically made for mass production like intent, claimed as 4X speed? i guess because of the 4 print head, each one with only normal speed. "hybrid hot end" they say? didnt you recognize the picture? its just the normal bowden type hot end, known for its mediocreness in reprap community. the xy plane build volume you probably need to divide it by 4 so its like what? 255mm x 115mm max footprint? well $300 3dprinter is better in that respect... open frame not closed control chamber? seriusly serious? if i need volume i'll buy 4 prusa, only $1200, twice the footprint, one damage is not all damage unit. but here's the kicker for the claimed as "serious printer".
"You are responsible for mounting the hot end to your printer, which may include custom mounting brackets, depending on the type of printer you own. The kit does not include enough tubing for bowden applications. You must supply your own tubing
pay $6000 for that "serious printer" and then i can offer you $60 professional advice on which is the better bowden tube its nothing! 1/100th of your total serious investment, and then you can buy it from china ebay.
about the custom mounting bracket? good luck on that! for a $6000 price, they cannot afford to give away the adequate length of bowden tubing
and whats the point of mass production of ugly looking FDM print output? for "more serious printer" cheapest "print volume/price" around, in US region i'll vote for
http://shop.re3d.org/#product-slider (unassembled) still open frame, if you need closed chamber at that volume you need to think 5 or 6 figure invesment...
