Author Topic: Raspberry Compute Module 4 Board with ISO Interfaces  (Read 3461 times)
Offline sukhoiTopic starter
  • Country: bg
« on: February 12, 2021, 08:41:27 am »
Dear All,
Our Team believe in Open Source Projects. We are happy to submit CM Hunter.
It Will be totally Open Source after our Campaign.
Galvanically-Isolated Modbus, 1-Wire, CAN | LAN | HDMI | LCD | USB | RTC | RELAY | QT Application for small Displays | Open Source
This is not just another Raspberry PCB.
Not just IO Board.
Open Source - Hardware and Software.
This Carrier board was created by engineers for engineers, creators, learners, hobbyist.
CM Hunter Integrates the most common communication protocols:
RS485/Modbus isolated
CAN 2.0B isolated
1-Wire isolated
HDMI 2.0
ETHERNET Gigabit
USB 2.0
2.4 GHz, 5.0 GHz IEEE 802.11 b/g/n/ac wireless /some CM4 versions/
Bluetooth 5.0, BLE /some CM4 versions/
+ Real Time Clock, Relay, LCD Display, SD/MMC card, Cooling Fan
You could support us here:
https://www.kickstarter.com/projects/andreasebrle/raspberry-compute-module-4-carrier-board-with-iso-interfaces?ref=1ljqu6&token=79d23762
1172382-0
