Author Topic: MEATER: The Only Wire-Free Smart Meat Thermometer on IGG  (Read 10550 times)
Offline KalidorTopic starter
« on: October 25, 2015, 08:23:08 am »
https://www.indiegogo.com/projects/meater-the-only-wire-free-smart-meat-thermometer
Is it possible that a battery and a WiFi & BT module can withstand cooking temperatures?
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual.
Re: MEATER: The Only Wire-Free Smart Meat Thermometer on IGG
« Reply #1 on: October 25, 2015, 08:40:31 am »
Not for long, if you go for well done it will go above 140C and the battery and BT module will both fail, the battery probably explosively, which would be somewhat unhealthy in a gas oven with a naked flame and some volatile organic solvent vapour in a near ideal stoichiometric mix.
Offline crispy_tofu
« Reply #2 on: October 25, 2015, 08:49:19 am »
Not to mention the cycling of temperatures... wouldn't last for long :popcorn:
And then there's the people that are going to say that the Bluetooth radiation would poison the food...
« Last Edit: October 25, 2015, 08:51:18 am by crispy_tofu »
Offline pbendel
« Reply #3 on: October 25, 2015, 09:00:50 am »
Somebody should do a teardown on the probe, maybe TEG powered from the temperature difference from one end of probe to the other end.  Maybe destructive testing, run a thermal oven hotter that a barbeque (or just use a barbeque) and see if anything fails...
Offline Marco
« Reply #4 on: October 25, 2015, 09:52:48 am »
The holder seems to be a charger, maybe they use capacitors to store energy? How much energy does it take to blip temperature say every 5 seconds? It's a pretty chunky piece of metal, you could put quite a lot of capacitance in there and the electronics can be in the tip at relatively low temperatures.
I could see this working, but building it to 59$? That's quite an achievement.
« Last Edit: October 25, 2015, 09:56:12 am by Marco »
Offline crispy_tofu
« Reply #5 on: October 25, 2015, 09:55:34 am »
According to the Kickstarter, looks like it uses a AAA battery, which can 'recharge the MEATER up to 100 times'. (unless you're talking about the probe)
There's a battery compartment on the back.  ;)
« Last Edit: October 25, 2015, 09:58:31 am by crispy_tofu »
Offline Marco
« Reply #6 on: October 25, 2015, 10:00:52 am »
"Notch: Safe insertion line"
Does that mean that if it's not inserted in a piece of meat that deep it's not safe?
Offline crispy_tofu
« Reply #7 on: October 25, 2015, 10:07:11 am »
Yep, it'll turn into a projectile.  :-DD
« Last Edit: October 26, 2015, 09:32:42 am by crispy_tofu »
Offline mzzj
« Reply #8 on: October 26, 2015, 09:26:12 am »
You need only the antenna outside of the meat thus reducing the temperatures to below 100C.
Online mikerj
« Reply #9 on: October 26, 2015, 02:34:13 pm »
Wonder how well it works in a microwave  >:D
« Reply #10 on: October 26, 2015, 04:15:05 pm »
As soon as the door is closed WLan & BT is blocked, no need to switch it on  ;D. You can try it with your phone.
The backers with a microwave oven (combined) will probably complain.   :-BROKE
Offline kfitch42
« Reply #11 on: October 26, 2015, 08:33:49 pm »
Probably.
 I assume the battery is near the tip. This lets them use the meat as insulation to keep from causing thermal runaway in the battery. If they can get a battery rated for "industrial" temp range (125C) they might be OK. Cooking temperatures for meats ( http://www.foodsafety.gov/keep/charts/mintemp.html ) are below 100C. They probably only have a temp sensor (something like a K type thermocouple?) and the bluetooth antenna in the dark part that is not in the meat.
Online tom66
« Reply #12 on: October 27, 2015, 01:01:33 am »
Does it need a battery?  If the bluetooth part transmits only every minute or 30 seconds you could probably get acceptable performance from a bank of capacitors.
A BLE module I have uses 15mA during transmit for around 1ms and sleeps the rest of the time. That's about 15uC for one transmission. Say you need to do 100 transmissions in every cooking session, excluding quiescent losses for now, that would mean you would need 1.5mC, or at 3V about 500uF. That's within the realm of a high temperature electrolytic, or even a few large format ceramic capacitors.
Offline Bud
« Reply #13 on: October 27, 2015, 01:42:11 am »
They've done their safety research to mitigate liability claims in case people used it as a rectal thermometer
Offline Marco
« Reply #14 on: October 27, 2015, 11:17:06 am »
I'd try 50V X7R ceramic capacitors derated to 12V, LoRa with an external BT/WiFi relay and put it together with 80Au/20Sn solder. That should make it pretty much indestructible.
Offline fcb
    • Electron Plus
« Reply #15 on: October 28, 2015, 07:05:37 pm »
"DEREK - Your meat is ready!"
What's not to love.
Offline crispy_tofu
« Reply #16 on: October 28, 2015, 09:01:31 pm »
Obligatory (sfw):
Offline LukeW
« Reply #17 on: October 29, 2015, 12:43:36 pm »
Energiser E92 AAA datasheet gives the nominal charge capacity as 1100 mAh (at 25C, 25mA discharge to 0.8V)
So charge capacity of each probe should be 11 mAh, assuming 100% efficiency.
Offline kfitch42
« Reply #18 on: October 29, 2015, 02:33:53 pm »
The meater page says:
Rechargeable Battery: Lasts 48 hours or more of continuous cooking between charges
I will take a swag at 1 transmission per minute. 48*60 = 2880 transmissions
2880  * 15mA*1ms  = 43200(mA)(ms) = 43.2(mA)(s) = 0.012 mAh
Did I foul up my math? That actually suggests that transmit power is not the limiter. Maybe they are doing 1 transmission per second. Or perhaps they need to transmit BLE at crazy high power (since they are likely to be in something resembling a faraday cage (oven or grill).
Offline EEVblog
« Reply #19 on: November 03, 2015, 12:02:35 am »
FYI, the user "meater" was a fake account with a bogus website. Banned.
Offline Srbel
  • Country: cs
  • Electronics engineer
Offline amyk
« Reply #21 on: November 10, 2015, 08:33:31 am »
There are ultra-high-temperature batteries available up to 200C:
http://www.steatite-batteries.co.uk/electrochem-lithium-batteries.html
Probably not cheap though, if you have to ask for the price...
« Reply #22 on: November 11, 2015, 07:09:14 am »
These are non rechargeable batteries, smallest size is AA.
The contents of the batteries are highly toxic and require special disposal procedures, additionally they may explode if shorted.  :scared:
