Author Topic: Veritasium Snatoms kickstarter  (Read 4790 times)
Offline _Andrew_Topic starter
« on: November 13, 2015, 12:01:48 am »
Not electronics but a cool science teaching aid kickstarter from Veritasium called Snatoms.
I consits of a kit of magnetic representations of atoms (6 carbon, 12 hydrogen & 6 oxygen) which can be used to assemble and understand chemical structures. The kit will contain enough atoms for the chemical structure of glucose. If it is successful then others kits will lightly follow.
https://www.kickstarter.com/projects/veritasium/snatoms-the-magnetic-molecular-modeling-kit
https://youtu.be/He30D8M5fNc
Offline hagster
Re: Veritasium Snatoms kickstarter
« Reply #1 on: November 13, 2015, 01:33:32 am »
As I'm not a chemist or physisist, I can't comment on the utility of this particular kickstarter, but Vertitasium makes some really top notch science content on YouTube and deserves to succeed IMO.
Offline ez24
  • L.D.A.
« Reply #2 on: November 13, 2015, 01:44:50 am »
thanks
Offline edy
    • DevHackMod Channel
« Reply #3 on: November 13, 2015, 05:51:11 pm »
It's definitely a cool idea. The only problem is that when it comes to double-bonds and triple-bonds, you will need different "atoms" fabricated with different orientation of flat-surfaces and magnets.
Take for example CARBON. The traditional 4-bond pyramidal orientation puts the 4 bonds as all going out in equally distributed directions in 3D around the atom. That's great for methane, ethane, butane... etc.. But say you want a double-bond on the carbons to make ethylene (2 bonds join the carbons), or acetylene (which has 3 bonds joining the carbons).
In those cases, you need to have different positions of the "flat" sides of the balls, to reflect the geometry of the bonds in space, and different numbers of magnets (and even different strengths if you want to simulate how much "energy" it takes to break and form the bond).
Then you have NITROGEN. It can form 3 bonds, but when bound to itself to form nitrogen gas, all 3 bonds are on the same side to link to the other nitrogen. This is very different from ammonia. And once again, 3-dimensionally you can't just stick 3 bonds at 120 -degrees apart around the equator. There is a slight bend towards once side due to electron cloud density on the top which warps it.
It's a great start, but really suited to very basic learning. You really need something in virtual reality here with gloves and 3D VR goggles like a chemical MineCraft or something that Microsoft Hololens can do.
Offline Kalidor
« Reply #4 on: November 17, 2015, 04:45:07 pm »
Not only double bonds, also single bonds have different angles in the same element. For example O angle in H2O 104.5deg and in Ethylene oxide (C2H4O) 61.6deg. But thats not so important to learn the basics in chemistry. It gets even more fascinating with H2O2 where the angle in the gas phase is 94.8deg and in the solid phase is 101.9deg.?
But this is not such a problem it's just a model to teach kids, it does not need to be shown everything but the real problem will start if he tries to introduce sulfur, it has 8 oxidation states and 4 are common, he will end up with a lot of models or one that's no ball at all.
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual.
