Author Topic: Geniuz Qi phonemount  (Read 2224 times)
Offline cs.dkTopic starter
« on: May 05, 2019, 10:04:49 am »
To bad this isn't get more backing.. I think it looks like a clever device.
https://www.kickstarter.com/projects/geniuzmount/a-natural-and-compact-car-mount-with-fast-qi-wirel
Does anyone know an alternative, if the kickstarter fails?
Online Gyro
Re: Geniuz Qi phonemount
« Reply #1 on: May 05, 2019, 10:14:15 am »
I thought windscreens were for seeing the outside world through.  :-\
"Sorry, I didn't see her officer, she was hiding behind my mobile phone!"
« Last Edit: May 05, 2019, 10:23:12 am by Gyro »
Best Regards, Chris
« Reply #2 on: May 05, 2019, 10:23:08 am »
No one says it must be placed in the windscreen..
I think it's cool with the automatic grabbing function.. I know, it's not need to have, but still a nice gimmick. https://ksr-video.imgix.net/assets/024/030/478/e0cddf5c396a5b2bded06bab1cb59a20_h264_high.mp4
Online Gyro
« Reply #3 on: May 05, 2019, 10:26:27 am »
Hmm, all the images and video show it hanging off the rear view mirror.
Best Regards, Chris
« Reply #4 on: May 05, 2019, 10:29:18 am »
Well, that's their decision - I won't have my phone up there.
Online PlainName
  • Country: va
« Reply #5 on: May 05, 2019, 01:12:02 pm »
I already have a magnet mount so I know these work great. Their choice of attaching to the rear view mirror seems a bit off - superficially it looks great, but the weight off to one side is surely going to result in the mirroring moving over bumps. Nevertheless, I backed this just for the plain mount since it solves the issue of finding some empty and flat space on the console to mount a magnet.
Offline luxetveritas
« Reply #6 on: May 05, 2019, 01:59:04 pm »
When navigation is running would a Qi supply even keep up with power usage?  My phones lose battery capacity even when plugged in (unless it's a high power charger) so I can't imagine a Qi supply would deliver enough.
« Reply #7 on: May 06, 2019, 03:10:47 am »
My Mate 20 Pro can just keep up (the battery level keeps constant) with a cheap Qi charger. The adapter i'm using is 5V 500 mA. The Qi holder it self can take 9V or 12V 1A, that should be enough to charge.
Offline edy
    • DevHackMod Channel
« Reply #8 on: May 08, 2019, 03:25:31 am »
I find it strange that they only asked for $20,133 to make this project. That is already a red flag, don't you think? This cannot be an original build for that money. They must be trying to buy a container at very cheap cost from a new run coming out of a Chinese factory, or it is the manufacturers doing it. Still, I can't understand the $20,133 needed for this campaign to KickStart.
Second, where is it getting power for charging? There appear to be 2 models... the cheaper $14-25 model has no Qi wireless charging so it wouldn't plug in. But something has to power the "auto clamp" feature... is this a rechargeable internal battery that you have to charge up once in a while, or does it have to be plugged in somewhere all the time? If you mount it to the rear-view mirror how will you route your cable? As far as I know the only option to power stuff in the car is through the 12V cigarette lighter adapter or some cars have 5V USB ports now. The more expensive $29-39 model has the Qi charger built in.
And by the way, what is this on eBay for $23:
https://www.ebay.com/itm/New-15W-FAST-QI-Wireless-Car-Charger-Infrared-induction-Mount-Phone-Holder-Stand/153259411879?hash=item23aef909a7:m:mHECymjc3-Yhf0NObtMxpzg
Here is a video of a similar one with auto-clamp and wireless charging:
https://youtu.be/t5ySauRM8-Y?t=498
« Last Edit: May 08, 2019, 03:28:40 am by edy »
Online PlainName
  • Country: va
« Reply #9 on: May 08, 2019, 05:14:00 am »
My understanding was that the cheap one (that is, the one without QI charging) wouldn't have the holder - it is merely a magnet on the end of a stick and the phone attaches via a metal plate stuck to the back of it or sandwiched between phone and case. That's the sort I currently use.
The price seems a bit high for that in comparison to Ebay/Amazon products, but in absolute terms it's reasonable - far cheaper than I could make myself!
I agree that the funding level looks dodgy (the non-integer value you quote may well be due to currency conversion) but I've backed worse ones and got a result in the end. Don't care if it's a manufacturer, or a container offload so long as I got one :)
« Reply #10 on: June 01, 2019, 06:58:14 am »
Thanks for pointing that one out.. Just received it from Amazon :-+
