Author Topic: Blynk. Build an IOS or Android app to control Arduino, RasbPi, ESP8266 over eth.  (Read 3449 times)
Offline JacquesBBBTopic starter
Hello all,
I have seen this project on Kickstarter.
https://www.kickstarter.com/projects/167134865/blynk-build-an-app-for-your-arduino-project-in-5-m
Its look quite promissing, as it allows to construct a dedicated  IOS or Android App  to control
a arduino like board, RaspberryPi and maybe also ESP8266 over ethernet in an easy way.
What do you think ?
Offline Laurynas
  • Country: lt
backed. let's see what will they build :)
Offline Mechanical Menace
I can imagine users outgrowing this way too quickly to justify it's cost. The Android SDK works well and has decent libraries. I've never had to touch an iOS device but I'd bet their SDK is just as good, maybe better in some ways, maybe worse in others...
If you're using a RasPi and learning to use Python on it you may as well use something like this https://play.google.com/store/apps/details?id=com.hipipal.qpyplus&hl=en_GB or this https://itunes.apple.com/us/artist/jonathan-hosmer/id485729875?mt=8&ign-mpt=uo%3D4 and if you're using C/C++ why not just use the SDK?
« Last Edit: February 14, 2015, 02:20:16 pm by Mechanical Menace »
Second sexiest ugly bloke on the forum.
"Don't believe every quote you read on the internet, because I totally didn't say that."
~Albert Einstein
