Author Topic: I just Kickstarted a KVM Switch like device but for electronics  (Read 1730 times)
Offline bleckers
I just released the Port MuxR Kickstarter - https://www.kickstarter.com/projects/sensordots/sensordots-port-muxr-a-kvm-switch-but-for-electron
It's a 8/16 channel, bi-directional, switched bus multiplexer that lets you branch out programming cables, logic analysers, debuggers and more.
Check it out and let me know if there's anything that you want to see or change :D
« Last Edit: March 03, 2019, 07:42:42 am by bleckers »
Offline dsegel
Re: I just Kickstarted a KVM Switch like device but for electronics
« Reply #1 on: March 05, 2019, 05:08:36 am »
This is a cool idea. It's one if those things that I've needed once or twice in the past, but never enough to make something like it myself.
What kind if bandwidth does it support? How fast a signal can it switch?
Offline bleckers
« Reply #2 on: March 05, 2019, 06:59:30 am »
The rise/fall time of the FETs is about 0.15ns which is calculated from its typical on state resistance (3 ohm) and load capacitance (50pF), so it could technically support into the GHz range under ideal conditions. However the circuit itself and connectors are definitely not designed for that. I am going to have some more in depth tests in the coming updates, but with what I have on hand currently, 50MHz square waves get through without too much attenuation and distortion (so say ~200Mhz bandwidth currently as a safe guess).
« Last Edit: March 09, 2019, 06:40:58 am by bleckers »
Online agehall
« Reply #3 on: March 05, 2019, 11:08:27 am »
Nice project! I wish I had a need for such a board...
The following users thanked this post: bleckers
Offline greencardigan
« Reply #4 on: March 08, 2019, 11:06:24 am »
Cool, I’m going to check this out!
Offline chickenHeadKnob
  • doofus programus semi-retiredae
« Reply #5 on: March 08, 2019, 10:01:38 pm »
Your specification list should mention if it is Break before Make, or make before break or software settable. You are selling to engineers!
I would make the assumption break before make, but it it is nice to see in black and white.
Offline bleckers
« Reply #6 on: March 09, 2019, 05:06:12 am »
Currently the software is just the order in which you issue commands (port enable/port disable e.g. you can have multiple ports enabled), so it's based on how you send the commands. But it could definitely have a setting in there to do this no problems :)
I'll make a note of this and update the software.
Edit: this was added to the firmware and posted in an update.
« Last Edit: March 15, 2019, 03:55:06 am by bleckers »
Offline macsboost
« Reply #7 on: March 10, 2019, 01:18:15 am »
A Mother Muxer :-DD
