I occasionally use something similar called the Easy Macro, which has a plastic lens mounted on an elastic strap.
https://www.easy-macro.com/The advantage is that the one magnifier will work on almost any phone or tablet device, potentially even in a case, unlike the many models of the iCROS.
You can also double the Easy Macro up to get extra magnification - but of course the image quality will suffer somewhat.
