Author Topic: Multi Platform Oscilloscope and Signal Generator  (Read 3578 times)
Offline digger72Topic starter
« on: December 16, 2021, 04:20:11 pm »
This Project is on Moonfunded ( Moonshot Jr's Crowdfunding Platform).
The key idea is a script based Signal Generator and Oscilloscope so you can write code to generate a pattern or capture waveform using a script. The connection is using the USB Port. The Entry Price is $39 for early birds.
https://moonshotjr.com/moonfunded/project/mutliplatform-multi-os-oscilloscope-signal-generator/
