Author Topic: Most Ironic Kickstarter Ever  (Read 4267 times)
Offline EEVblogTopic starter
« on: February 20, 2014, 10:57:48 pm »
A book on "how to succeed at kickstarter" fails to reach it's funding goal!
http://www.kickstarter.com/projects/ilex-press/kickstarter-succeed-first-time-a-guide-to-crowdfun
Offline GiskardReventlov
  • How many pseudonyms do you have?
Re: Most Ironic Kickstarter Ever
« Reply #1 on: February 20, 2014, 11:01:45 pm »
That's a big goose egg!
Offline grumpydoc
« Reply #2 on: February 20, 2014, 11:05:34 pm »
 :-DD
Offline calexanian
    • Alex-Tronix
« Reply #3 on: February 21, 2014, 05:58:41 am »
How to get rich quick by writing get rich quick books. Either it works, or the universe collapses into a singularity.  :-/O
Charles Alexanian
Alex-Tronix Control Systems
Offline BravoV
  • +++ ATH1
« Reply #4 on: February 21, 2014, 06:05:32 am »
An instantaneous image pop out from my head when reading it.
Offline Kjelt
« Reply #5 on: February 21, 2014, 07:37:47 am »
So what happens now, do the backers get a refund or is the author getting his money and does not even have to write a book, how does this work (could have used the book)  :-DD
« Reply #6 on: February 21, 2014, 09:12:22 am »
It's Kickstarter. The target wasn't met, so no one gets charged.
Offline Psi
« Reply #7 on: February 21, 2014, 09:57:44 am »
Next up..... on kickstarter
"Kickstarter is awesome but we need your money to create an even better website to crowdfund projects. We will build on the ideas of kickstater with added features and useability."
« Last Edit: February 21, 2014, 10:34:43 am by Psi »
Offline cybermaus
« Reply #8 on: February 21, 2014, 10:33:31 am »
He is considered extremely successful at Kickstarter because his triggertrap raised 3 times its goal.
Two things spring to mind:
- Apparently it does not matter if the product is successful or good, the benchmark is only if you were able to raise money for it. (Surely this is con-man's heaven ? )
- Did the uCurrent not clock in at x12? You should write that book Dave, you are much more qualified. (I would not back such a type of book though, not even from you)
