He is considered extremely successful at Kickstarter because his triggertrap raised 3 times its goal.
Two things spring to mind:
- Apparently it does not matter if the product is successful or good, the benchmark is only if you were able to raise money for it. (Surely this is con-man's heaven ? )
- Did the uCurrent not clock in at x12? You should write that book Dave, you are much more qualified. (I would not back such a type of book though, not even from you)
