Author Topic: New project on Kickstarter. Need a review. Multifunction device - oscilloscope .  (Read 1433 times)
Offline hugeone
I have a poll on my facebook about the my design. Feeedback appreciated.
« Last Edit: February 25, 2018, 07:29:32 am by hugeone »
Offline rhb
I started a similar project a year or two ago.  Ultimately I abandoned it because it was not really sufficiently different from a slew of Chinese eBay offerings to be worth the trouble.
At present I am working on doing something similar using the Zynq.  Rather than design hardware which would be expensive to produce in low volume, I'm focusing on writing open source FW for Zynq based DSOs and dev boards.
DSOs have the limitation that the low end is just 8 bit ADC.  But by varying offsets and attenuator settings in software one can achieve more accuracy by successive approximation to implement  higher resolution.  A cheap DSO will sample at 1 GS/S so it has a 500 MHz acquisition BW.  That's quite a high spec SDR for things like real time spectrum analysis. For listening and monitoring purposes one could split the input into a portion that is being actively decoded and spectrum waterfall display that updates  30-120 times a second.  That would get around the BW limitations of USB and Gb ethernet.
BTW  Thank you for your article on UBIFS.  I found it very helpful.  I did encounter issues related to properly specifying the size of the target device when trying to mount 3rd party images.  The error messages from mtd-utils were less than informative.
Online blueskull
  • Country: cn
  • Power Electronics Guy
Rule of thumb when competing with Chinese: if you don't have any parts made of unobtainium (ASICs, etc.) nor have any sexy, exotic algorithms running in a well encrypted CPU, then don't bother.
In your case, the code is not that much advanced compared with DSO138, and the hardware is nothing new and exotic.
For such apps, Chinese companies can cook the same thing from scratch even without cloning your design in a few months or even weeks with only 20% margin above BOM. How can you compete?
Offline chriswebb
One thing specifically on your kickstarter is that you mention in one place the third stretch goal would be 30 mhz and at the bottom its only 10 mhz.
Always learning. The greatest part of life is that there will always be more to learn.
The following users thanked this post: hugeone
Offline abraxa
  • Sigrok associate
I run small advertising company
I suggest you have one of your designers make nice graphics. The green/red color for the condensed type? It's really easy to glance over because it's hard to read. Green/red/blue/yellow? Eh... sorry... just no.
Also, typos:
advances features
921600pbs
Clock surve
I²C vs. I2C
Output volatage
streatch goal
Also, I don't really see a buffer size for the oscilloscope portion and whether all those features can be used at the same time or not. Also, the 8 MHz analog bandwidth is kinda odd. You'd need at least 16 MSPS to make use of that. What happens if the 10 (30?) MHz stretch goal is unlocked? Do you then increase the sample rate as well? If not then the stretch goal is completely pointless.
Overall though, I'd say the only way to set yourself apart here is with the software. If it's good and easy to use, this would be a huge bonus. I'd say you should highlight it more and give better screenshots (e.g. showing functional areas one-by-one). Also, how are the debuggers actually *used*?  Giving examples for certain use-cases would give people an idea of what to expect.
« Last Edit: February 21, 2018, 07:17:30 pm by abraxa »
Offline hugeone
Thank you very much for your answers.
Actually I should write "micro" and I am the only designer  :)
Quote from: abraxa
Thank you.
Quote from: abraxa
It is not exactly the truth. Especially is we consider signals with high bandwidth consumption - for example the square wave. If you consider the 1MHz square (having 10 samples / period) - 10MHz bandwidth is a minimum.
