Author Topic: ESP32-S3 PowerFeather: Low power, solar capable, Li-ion/LiPo Powered Dev Board  (Read 14481 times)
Offline powerfeatherdevTopic starter
  • Country: ph
    • PowerFeather
Hello all,
I want to introduce ESP32-S3 PowerFeather, a dev board that should make it a little easier to create solar + Li-ion/LiPo powered projects! It uses a charger IC that's smarter than most other similar boards: Texas Instruments BQ25628E; and also has an on-board LC709204F fuel gauge. Deep-sleep current can be under 20 uA. It has an Arduino/ESP-IDF SDK to help manage the use of the charger and fuel gauge, as well as the other power-related features. More details and link to documentation can be found on: https://powerfeather.dev/.
The following users thanked this post: tooki, selcuk
  • Country: ph
    • PowerFeather
Since the release of ESP32-S3 PowerFeather I’ve been working on a demo web app that lets users explore some of the features of ESP32-S3 PowerFeather, which I recently got to a decent state:
The web app is served from the ESP32-S3 PowerFeather (acting as an AP) and is accessed from the tablet's web browser. The part encircled in yellow shows the battery being charged at 1.5 A from the solar panel at the set MPP voltage of around 12 V.
The web app also displays other supply & battery telemetry information as well as some power management controls which are all built-in into the board and accessed using the PowerFeather-SDK API.
For those interested in the demo web app, maybe to try it on their PowerFeather or just to see how this was created: https://github.com/PowerFeather/powerfeather-demo.
  • Country: ph
    • PowerFeather
I made a showcase video for the ESP32-S3 PowerFeather: https://youtu.be/VF9AFk1Hf88
Offline tszaboo
Nice job on the board and the documentation. It's not easy to make something like this happen, and it shows that you put a lot of effort in it. Good luck selling it.
  • Country: ph
    • PowerFeather
Thank you for the kind words!
Offline tooki
It looks really nice. Any chance of getting it to the big distributors (DigiKey, Mouser, Farnell, Reichelt, etc.)?
(This matters because they’re all big enough that they take care of local VAT, whereas importing from smaller vendors means major surprise fees from customs.)
  • Country: ph
    • PowerFeather
I assumed that I wasn't big enough for Digikey et.al to consider. But it seems Digikey at least has an accessible application instruction page: https://www.digikey.com/en/resources/sell-on-dk
I'll try applying. If you know of the application process for the others, please do tell!
@tooki
Offline Kean
    • Kean Electronics
The common way to get listed on Mouser is via CrowdSupply.
A way to get on both DK & Mouser might be via collaboration with Adafruit.
