Author Topic: Projecta PCB magic making CNC machine  (Read 2019 times)
Offline rx8pilot
« on: August 22, 2016, 11:25:04 pm »
https://www.kickstarter.com/projects/intmindsco/projecta-the-ultimate-solution-for-the-pcb-printin
This looks super dicey with a 2 minute pass through the Kickstarter page and intro video. They are only seeking to raise $50k - what can you do with $50k? Not much at all. Another CNC PCB making machine.
Step one:
Cover your clad board with magic marker
Step two:
put in machine:
Step three:
Wait for it to magically do something behind an opaque case where you cant see anything.
Nuts.
Offline Kean
    • Kean Electronics
Re: Projecta PCB magic making CNC machine
« Reply #1 on: August 23, 2016, 12:01:12 am »
Super dicey indeed.  They probably have no idea how to commerically manufacture something.
I'm pretty sure these guys are from Egypt (Alexandria University*) not New York or Bangalore.
* see https://intminds.wordpress.com/about/
Offline frenky
  • Country: si
    • Frenki.net
« Reply #2 on: August 23, 2016, 06:47:40 am »
So they are selling 550$ cnc engraver that will scrape off some marker paint...
This can be done with any cheap cnc or 3d printer:
A cheaper option:
https://goo.gl/q5ys1D
« Last Edit: August 23, 2016, 07:50:05 am by frenky »
Offline frenky
  • Country: si
    • Frenki.net
« Reply #3 on: August 23, 2016, 07:02:09 am »
Or they are using laser to remove marker paint like this:
https://www.maglaboratory.org/wiki/PCB_notes
EDIT:
They are not... I rechecked photos on the kickstarter and I'm sure it's just a cheap engraver...
« Last Edit: August 23, 2016, 07:04:29 am by frenky »
Offline Xenoamor
  • Country: wales
« Reply #4 on: August 23, 2016, 12:12:21 pm »
You still have to drill it.
No mention of dual sided
No mention of accuracy or minimum pitch
I've tried both lazer removal of various paints/pens and I've also tried the CNC approach. I couldn't get either to work better than about 0.3mm
